Replace Hybrid Battery -- Where to buy dead battery to repair?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wayne Walter, Jan 4, 2017.
  1. Moving Right Along
    Moving Right Along Senior Member
    724
    579
    No batteries last forever. According to the folks at Cadex/Battery University, NiMH batteries are really sensitive to overcharge and deep cycling, and they have a high self-discharge rate. They also are sensitive to heat and have a tendency to heat up when charged and discharged too fast. Toyota's implementation of these batteries is their best-case scenario: the batteries are kept between 40-80% to prevent overcharge and deep cycling and the engine regularly charges the battery. By doing this, the battery's operating life is extended a long time. However, over time, the battery's ability to hold a charge diminishes and its tendency to self-discharge increases. This process is hastened if the battery was overheated, overcharged, deep cycled, or charged/discharged too fast on a regular basis.
    While there is some variation between individual modules in a battery pack, most will be within a small percentage difference of each other regarding operating life because all the modules in the pack were subjected to the same factors, whether just time or also temperature, over/under-charging, and/or rapid charging/discharging. So replacing the first failed modules while leaving the rest is likely to result in more failed modules. Similarly, when replacing modules or entire battery packs, the healthiest batteries will be the newest ones. This theoretically means that if you're going to replace the battery of a 2005 Prius with a remanufactured or salvaged one, you'd want to use a battery from a 2008 or 2009 model, since they have less wear. But the best option remains new battery packs from the factory, since they are guaranteed to have the least amount of wear.
  2. Wayne Walter
    Wayne Walter Junior Member
    Virginia
    Yes. my statement was oversimplified. While what you say seems true, evidence also suggests that niMh batteries respond well to reconditioning. And this based on the history of niMH AAA and AA batteries. There is a lot of experience with this. Some nimh batteries seem to keep getting reconditioned and continue working very long time with regular reconditioning, while some, under the same operating conditions fail to respond to reconditioning.
    At the above link (site didn't allow my link yet) you can see an example of someone who tests "surging" and "freezing" to revive otherwise dead nimh batteries. Based on some experts with labs that specialized in training to repair shops on how to properly service HV batteries, they routinely revive dead cells instead of replacing them using techniques based on understanding of the actual chemistry inside the nimh batteries. It apparently has to do with the crystals that form inside the battery and surging and re-cycling techniques can rejuvenate them.
    What's interesting about the site above is that the guy is "experimenting" and testing the theories about rejuvenating nimh batteries.
    There is tons of interest in rejuvenating rather than replacing dead rechargeable batteries because many people are concerned about the cost of replacing EV and HEV batteries. Personally, reconditioning the battery in my daughters otherwise wonderful car every few years for $600 would be nice versus dropping $3,000 to $4,000 on a brand new battery. And prices that low of $600 with a warranty begin to make since if merely rejuvenating versus replacing "dead" cells.
    Here's my idea. Most selling reconditioned batteries offer 6 months or 1 year warranty for about $800 to $1000. I will like to extend that warranty much longer for the same price but that won't be possible if it's necessary to always replace cells that begin to malfunction.
    And it won't be feasible if modules in a pack truly die around the same time regardless of being reconditioned or not. So I'm looking for hard evidence of the effects of reconditioning on the chemistry of batteries.
    AND I'm very keen on the new technique for testing batteries that is much quicker discovered at that university as a way to test newly designed batteries. But I want to use it to test reconditioned batteries to verify they will have longevity similar to a new battery.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    I ask again: What kind of "engineer" are you exactly ??
    It is impossible to do any kind of a definitive test to tell when a given component will fail.
    That is especially true of USED batteries.
    Please let us know what you find out about insurance.
  4. Wayne Walter
    Virginia
    Liability concerns while important seem far outside the scope this this thread or even this website, in my humble opinion.
    I'm simply not interested in discussing my background of engineering either. I'm a humble learner here.
  5. Wayne Walter
    Virginia
    Here's an interesting discovery:
    This is a list of patents that were filed and approved that are all based on excellent understanding of battery chemistry (chemistry is NOT my area of engineering expertise although I did study chemistry). I only read 2 of these patents so far, 6566844 and 20080079397. But it's most fascinating how totally "dead" batteries can be completely rejuvenated. One uses modulated harmonics signals to break up/disolve the crystals that are shorting out a dead battery. Another uses deep discharge at a high current to remove the memory effect--and the chemistry is teaching me that even niMh batteries have memory but just not as pronounced as niCd. So erasing the memory effect does wonders.
    6566844
    6504344
    6469473
    6441584
    5998968
    5698961
    5493196
    20080079397
  6. Sam Spade
    2,036
    1,023
    2017 Prius c
    I thought so.
    I'm done.
    Kris_Parker likes this.
  7. bisco
    51,946
    i think there is a thread here on re hydrating modules. brit john maybe?(n)
  8. Wayne Walter
    Virginia
    My engineering background certainly wasn't focused on chemistry which is the most relevant here.
  9. bisco
    51,946
    just be thankful.;)
  10. Wayne Walter
    Virginia
    Wow. I looked at this and it involves putting holes in the modules right? Whew.
    So far, I'm more interested in technologies that recondition dead modules using a capacitor to pulse a charge which dissolves crystals, and then reconditioning via deep discharge using higher current at lower voltages for near constant power to correct memory. Plus there is discharge and charge pulsing that can correct the internal impedance problems. And all that without drilling any holes.
    But I will read about hydrating. Perhaps that is also necessary in some scenarios.
  11. bisco
    51,946
    if you can figure something out, you'll be doing more than anyone else has to date. there isn't a reliable refurb out there to my knowledge.
  12. Wayne Walter
    Virginia
    Bisco, my thinking: one of the biggest ways to improve technology is cross industry learning. So I'm interested in how fork lift and other batteries for military equipment get reconditioned. There are some inventions and patents and a few companies pioneering the reconditioning for those. And that reconditioning industry seems more mature and better funded than for EV and HEV since the military pays dramatically more money for new batteries so the potential savings of reconditioning is greater.
    Just some musings as I research.
  13. Wayne Walter
    Virginia
    Do you know what I really want right now?
    Dead Prius modules. I want to experiment on modules that others already threw out as trash.
    I would test their voltage, capacity, impedance, self discharge and then try the different methods
    for rejuvenating that are in those patents and see how well they improve.
    Also, I want to find out how to graph the voltage curve during discharge like is shown in several
    of those patents as a measure of the batteries performance compared with new batteries.
  14. bisco
    51,946
    one question i have always had is, can it be economically viable to dismantle a battery, recondition it and put it back together vs $2,000. for a new battery.
  15. Wayne Walter
    Virginia
    Brand new batteries seem to cost much more than that from dealers. In fact, I see reconditioned batteries with 4 year warranties at over $2000
    So it seems viable but who wants to buy a reconditioned battery that fails often even if the warranty will cover it for a year? I don't. So I'm researching how to confirm the reliability of batteries after reconditioning. It's difficult to find hard data and research into this.
    However, scientifically, the chemistry is such that it seems clear that it's possible to "reset" the ions inside the battery, dissolve crystals, and reduce impedance by different reconditioning techniques. If that is true, then it will greatly extend the life of a battery nearly to the original life when it was new.
  16. Wayne Walter
    Virginia
    Also it seems clear that you can measure the chemistry inside the battery for it's health by measure those same factors like self discharge, internal impedance, capacity, and voltage to determine that the internal chemistry is comparable or close to that of a new battery. It's crucially important to be able to measure this.
    I don't want to "rejuvenate" a module and it works for only a few weeks and fails again. I don't want this as the business nor for the customer to have this frustration.
  17. Wayne Walter
    Virginia
    (And not for my daughter either! :) )
  18. Wayne Walter
    Virginia
    Hmmm I just bought 12 "dead" Gen II Prius modules on eBay for $68. This will give me something test rejuvenating. If only 10 of them can be rejuvenated that will be $400 worth of modules for $68. Otherwise it will be a $68 learning experience. ha ha
    SnT08Prius and MrStroke like this.
  19. Wayne Walter
    Virginia
    In the Cadex Battery Univerity, they talk about how in the military they user Nickel based batteries for aircraft and they have very strict battery maintenance schedules which includes reconditioning by discharging to 0V for 24 hours and reusing them over an over. They explain how it's done and I expect that will work with HV niMh car batteries also.
    If military aircraft engineers recondition and reuse niMh and niCd batteries where you they extreme need for reliability more than automobiles, then that should be good for automobiles also.
  20. Moving Right Along
    724
    579
    Good luck, but be careful. Even though the components of NiMH batteries aren't as toxic as the components of NiCd batteries, they can still overheat and burn and/or electrocute you. Since you're buying failed modules which are presumably closer to tolerance limits, safety is an important consideration.
