Replace Hybrid Battery -- Where to buy dead battery to repair?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wayne Walter, Jan 4, 2017.
  1. Wayne Walter
    Wayne Walter Junior Member
    Virginia
    I do always appreciate warnings. Thank you.
    I'm aware that they can overheat and burn. The Turnigy Reactor does have both a battery and an internal temperate monitor (according to the manual) but I don't know how to use the battery temperature monitor yet. Still, the manual strongly warns to never leave it charging or discharging unattended and not to have the battery or charger near anything flammable.
    I'm not willing to watch it for hours--so this seems the most likely danger. I'm considering how else to protect against fire in my garage. Keeping away from flamables is good advice. But I'd like some kind of thermal cutoff in addition to chargers own protections that will disable the charger if the temperate of the batteries climbs.
    As far as electrocution, with single modules at only 6 to 8 volts they seem harmless until hooked in series in the battery. I did order Class 0 gloves for handling when bolting or unbolting the bus between the module terminals. Once those buses are off, it will be harmless.
    Any suggestions about avoiding fire?
    or any other advice?
    #81 Wayne Walter, Jan 6, 2017
  2. strawbrad
    953
    1,007
    Hmmm I just bought 12 "dead" Gen II Prius modules on eBay for $68. This will give me something test rejuvenating. If only 10 of them can be rejuvenated that will be $400 worth of modules for $68. Otherwise it will be a $68 learning experience. ha ha
    It will be a $68 learning experience. That's ok because you have soooooo much to learn.;)
    The real lesson is realizing the highest and best use for dead modules.
    DI-149 USB Data Acquisition Starter Kit and
    Gen II Prius Individual Battery Module Replacement | Page 82 | PriusChat post # 1639
    Brad
  3. Wayne Walter
    Virginia
    Very cool Brad! Thanks for sharing. I love the Daq.
    Brad did you ever try to refurb via zapping, deep discharging, or other technique to revive "dead" cells?
    And are cells considered dead by others already really totally beyond repair?
  4. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    A bit of history and a great read:
    "The following year, we got sponsored by Yardney Electric out in Pawcatuck, Connecticut. They made batteries for nuclear powered submarines and their chemistry was silver/zinc, and that was the highest energy battery you could get in those days (1970's), about five times better than the lead acid ones."
    Mike Corbin on Quicksilver, the motorcycle that held the electric land speed title for 38 years
    strawbrad likes this.
  5. strawbrad
    953
    1,007
    Wayne,
    You really have a lot of homework to do. The answers are all there in several hundred past posts. I'll add Hybrid Automotive's website to your reading list. He is also PC member jeff652. Jeff sells the whole pack chargers he recommended to you. He is also a champion of deep discharging.
    I have a zapper I'll sell you cheap.;)
    You keep calling the six cell modules "cells". What I have found is just one cell of the six fails and the other five can have like new performance. These modules will measure 6.XX volts. The five good cells will retain 1.2 volts and the dead cell will be at the .XX volts. I have not found a way to bring these back from the dead.
    Brad
  6. bisco
    51,946
    one question i have always had is, can it be economically viable to dismantle a battery, recondition it and put it back together vs $2,000. for a new battery.
  7. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Check out Battery Secrets - Tesla Chargers . The main claim is that it is possible to keep lead-acid batteries working forever with the proper charging strategy. I think the technique is to pulse something like 18V at a rate slow enough to not cause overheating. Note that the primary guy running the website died recently and those remaining are still trying to pick up the pieces. I have an outstanding order for a 12V charger/reconditioner that I'm leaving in the queue on the hope that I'll actually get it eventually. Documents should still be available without delays, but mine is a build to order item that didn't get done.
  8. Wayne Walter
    Virginia
    Brad,
    Brad, that's cute about selling me zapper cheap. I like your personality in how you deal with people. :)
    Also, I really did try to keep the terms module versus cells straight--must have been a typo. Sorry.
    But now that I'm more educated on niMh batteries, Jeff's site makes a lot of sense about deep
    discharging to extend battery life. I love his graph's and evidence to that effect.
    But his system does have the advantage that an individual (like my daughter) can use it themselves but
    it doesn't seem like fast enough charger/discharger to use in a reconditioning business. And the discharger
    requires manually watching the voltage drop during deep discharge with a meter. Again, it's affordable
    for individuals and easy to install and use so it's smart idea.
    I do love his idea to charge/discharge or recondition the entire pack in the car without removing it except
    that means the car is out of service until the reconditioning completes.
    Brad, is there a way to use the Turnigy Reaktor 1200W to charge the entire battery pack using a voltage
    transformer? Hmmm. I just got the idea to ask the HobbyKing folks and will do so. What do you think?
    Also, several threads do say that "balance" the entire pack by charging it, can you do that with a Turnigy
    Reaktor 1200W without a transformer?
  9. Wayne Walter
    Virginia
    It seems really clear from my research that there is definite value in pulsing batteries at higher voltage to restore their function to like new. So far the only 2 ways that I seen was to manually spark the battery briefly which seems dangerous and the other was to charge up a capacitor and then let it discharge into the battery.
    The Tesla idea seems most interesting. It's sad the guy is gone. I share your interest!
  10. strawbrad
    953
    1,007
    No, a Turnigy Reaktor 1200W will not charge a whole pack at once. There are plenty of cheap options available. Do your homework and you'll find them.
    I actually have a problem with using the "b" (balance) word. Everyone on PC just knows that you have to "b" your cells and modules or your battery will surely fail. The problem is no one can give a clear definition of what "b ing" is or what happens when a module is "b d"
    Guy's you can't use the "b" word in it's definition. Let the flames begin.:cautious:
    Brad
    Kris_Parker and andrewclaus like this.
  11. Wayne Walter
    Virginia
    Oh I didn't intend to start flames. I hope this thread doesn't get flamed. I'll do my homework Brad. Thanks.
  12. Wayne Walter
    Virginia
    It's clear that I will eventually design my own pulser/charger/discharger/conditioner using an Arduino controller and circuits to monitor voltage during charging and discharging plus temperature sensor. That way, it can use a program to monitor the voltages automatically during discharging and control the current levels during charging and discharging plus have the ability to experiment with pulses discharge/charge during charging according to some patents. It will need inputs of the internal impedance of the battery too for controlling the need to pulse. Interestingly there are already open source circuits for Arduino that do most of this so it won't be a stretch to get all this done. Then the actual charging strategy will be up to the programming logic in the Arduino which will flexible way to experiment with charging strategies recommended in various online sources but have then totally automated. The only part of that unsure about yet is reverse charging back into the A/C power grid similar to how Solar power does it. That seems much better way to discharge batteries instead of dissipating it as heat.
    EDIT: Okay using in inverter to create A/C current will feed back into the grid. But my local power company will have to approve my system before they'll install a net meter.
    #92 Wayne Walter, Jan 7, 2017
  13. SnT08Prius
    SnT08Prius Active Member
    158
    187
    Bozeman, Montana
    What a fun thread. So much to learn about the Prius batteries. I'm in on this too. My 2008 Prius has almost 200,000 miles and never had an issue with the HV battery. But it seems trouble will not be far off and will be keen to have a "fix" at the ready status so the car is not off the road for ages nor cost $2,000 + to fix.
    Now to hunt down a spare battery to "play" with.... safely!! :)
  14. JC91006
    16,769
    8,567
    1. Buy a grid charger
    2. Buy a stock hybrid battery cooling fan from eBay.
    3. Build a discharger and load tester.
    4. Enjoy testing at 10x the speed of hobby chargers
  15. Wayne Walter
    Virginia
    I'm looking building an entire pack charger/discharger controlled by Arduino that can do the following.
    Microcontroller will be connected to the following:
    Charging:
    1. Monitor current flow charging using Hall effect sensor
    2. Control amount of current with MOSFET
    3. Monitor battery temperature using temperature sensor.
    4. Monitor battery voltage using voltage dividing resisters.
    5. Monitor battery internal impedance. (Didn't research how yet.)
    6. Control variable speed cooling fan for the battery.
    7. Display on LCD status information.
    8. Log to PC output or SD card of data collected.
    The idea is that during charging the microcontroller can charge with higher current
    until the battery temperature begins to rise and then reduce current to trickle charge
    until temperate rises to a point indicating the battery is full. Also will have time limit
    and voltage limits for safety.
    Discharging:
    1. Monitor current flow during discharge using Hall effect sensor.
    2. Control amount of current for discharge via MOSFET.
    3. Monitor battery voltage using voltage dividing resisters.
    4. Monitor battery internal impedance. (Didn't research how yet.)
    5. Discharge power back in to the power grid.
    This gets expensive with cost of an inverter, voltage regulator, step-down voltage and more
    parts to the circuit. (Now a light bulb to discharge the battery seems not so dumb. :))
    6. Display LCD status info.
    7. Log to PC output or SD card of data collected.
    For discharging, the idea is to discharge to specific voltage levels in the battery
    similar to Jeff's site of lower voltages for each of 3 cycles to deep discharge.
    Also there seems to be value when charging to pulse with short discharge followed
    by longer charging pulses until fully charged as this helps reduce impedance and heat.
    The micocontroller can control the alternating of discharge and charge pulses.
    Challenges to this design is the cost of high power components for charging and
    discharging the entire battery pack. A MOSFET rated for 110A and 800V is about
    $30. Hall effect current sensor salso get expensive for high power circuits over $40.
    Grid power supplies also add to the cost.
    So the circuit design, to keep costs down, needs to be able to use the same
    components for both directions of charging or discharging which seems possible
    using diodes. This will be better than separate circuits for charging and discharging.
    So I'm considering to build a low power version of this that can only charge a single
    module and verify all the circuitry works and the idea for different advanced ways of
    charging. Then I could invest in the high power version of the circuit after the kinks
    are all worked out of the low power version.
    In the low power version, it could run off a 12V car battery like the Reaktor so that
    it can discharge back into the 12V battery to reduce heat dissipation during discharge.
    But that won't work in the high power version.
    WAIT, here's an idea. What if for the high power version, I use a Prius battery pack
    instead of a 12 V battery to power the charger / discharger? Then when discharging
    the target battery, it is recharging the source battery. Hmmmm there's an interesting idea.
  16. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I respect correct terminology use, and have always had a problem with the "b" word as well. Apparently for most, that word is based on the hope that regular charging to 100% will benefit all the cells in the battery. And it sounds like some, if not many, have measured success with it.
    I also used to have a problem with the term "grid charger" for a high voltage trickle charger. To me, that connotes individually sensing and controlling every module in the battery "grid." But I finally found a site that defines that as a charger that uses 120 VAC (the "power grid") to charge the battery. (Maybe I was overthinking that one.)
    To the OP, I don't get the obsession with dumping heat. Have you done a kiloWatt-hour cost analysis? The capacity of the Prius battery is about 1.3 kWh, which costs about a dime in my area.
  17. Wayne Walter
    Virginia
    My concern about heat is because I want to discharge a battery as rapidly as is practical. My research shows that to recondition a battery you first fully charge it, then you discharge it down to a certain voltage. But you can discharge most of the battery quickly at high current like 80Amps similar to if it's turning the electric engine--that is also beneficial to measure it's capacity under a real load. But then you drop the amps much smaller to "trickle" discharge it down the rest of the way to the low voltage goal. This deep discharging reconditions it.
    Well during discharging most of it with a large load quickly, that can generate ginormous amount of heat in the discharging device like 1200W heater. It can catch fire if not kept cool with a fan and what if the fan dies for some reason. etc. Heat is bad. It's better to have cool running equipment.
    And you're right about it being only 10 cents. I decide to drop the idea of bothering with the power company setting up a net meter. I'll just pay them the 10 cents. ha ha.
  18. JC91006
    16,769
    8,567
    This sounds like a business venture now. 80amp discharge? Well I guess you could just run it in the car, that's free to build
  19. Eastside
    Eastside Member
    129
    82
    NorthVirginia
    re: OP " . . . Okay using in inverter to create A/C current will feed back into the grid. But my local power company will have to approve my system before they'll install a net meter. "
    OP, read a bit more about Virginia General Assembly and Dominion Electric. Recent legislation favors the power company.
    "Standby charges hobble the market for larger home systems and ELECTRIC CARS"
    "Dominion Power and Appalachian Power are at the forefront of a national pushback against policies like net metering that facilitate customer-owned generation. " 9/3/2015 powerforthepeopleva.com
  20. Wayne Walter
    Virginia
    Actually the amount of power is trivial in terms of cost for discharging a prius battery like another poster said-- only about 10 cents.
    So I'm not going to get the power company involved. When (or if) I bother to do this, I'll just feed it back and pay them for the that since it's mainly helping me discharge the heat.
    But due to the cost of inverter and voltage regulator needed, I'm going to just use a heating element or something similar to discharge the batter till it get low enough charge and then switch to a couple of light bulbs like Jeff does to further discharge it.
    I'm going to do much of this manually this first time around to experiment. But if this turns out viable business, then I'll automate it more.
    Frankly, I was desiring to play with building an Arduino Micro Controller device for long time. Now I have a good "excuse" to tinker!. And then build the "ideal" HV battery reconditioning system.
    So I'm ordering an arduino kit and do some of the basic projects and then work towards first using it to simply measure and record the voltage, impedance, capacity, temperate of the battery and allow graphing that. Then I can extend it to controlling more and more with baby steps by first controlling the switch over from heating element to light bulb, then switching to charging it.
    And I'll start first with charging a single module of 6 cells since the parts for that are much cheaper for tinkering.
    Only after I feel that I have enough knowledge and have a few battery customers, then I'll invest in building a full powered grid charger/discharger/reconditioner.
