Replace OEM 12V battery with Group 25 AGM
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cproaudio, Jul 9, 2015.
  1. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    I'm pretty sure that having an AGM battery is extremely important for both safety and reliability. That means the YBX9027 would be preferred, if you can get it to fit.
    Polish Prius likes this.
  2. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    I'm really liking the larger group 25AGM.
    I know there is no 2011 12v OEM battery running today that can hold off the ICE at the entire stop light while the heater blower is going.
    That 2011, old whippy battery requires the ICE to continually run to charge it if the fan blower is going.
    This battery almost never allows the ICE to run at all stops, during my travels. NICE.
    I'm enjoying more quiet time when I come to a stop.
    my2cents.
    #42 rrg, Mar 11, 2017
    j12piprius likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The ICE does not charge the 12 volt battery. It charges the 201 volt battery via the Motor/Generators. The Inverter charges the 12 volt battery and powers the 12 volt electricals when in READY.
    roughly 15:10 to 18:00
  4. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    That may be true but if you have an old weak battery, it won't keep charge. It would take the inverter constantly charging the weak 12v battery therefore could keeping the ICE on more often.
  5. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Mine would hold off the ICE before I replaced it at over 6 years old. I have a very long stop light when my side road meets the US highway and the ICE would never come on with the fan going, even when we had the below freezing temps for more than a week straight here. The only thing I do at that stoplight is click the headlights to parking lights.
    Replaced it with the BOSCH direct fit AGM battery made just for the Prius and the ICE still does not start at that long stop light.
  6. Magnetic Me
    Magnetic Me Junior Member
    LA
    So glad I installed a Group 25 battery in my Prius.
    Thought I’d add a few things I remember about doing the job which might be helpful to someone concerned this may be too difficult.
    I purchased the Bosch Platinum Series AGM Group 25 MMJ25 Battery at Pep Boys.
    While at the store I noticed some of the batteries didn’t have the little black plastic elbow shaped vent tube connector. I made sure to get one with my battery.
    The original Prius vent tube fit on to that new connector. I didn’t need to purchase new tubing. The vent hole on the opposite side of the battery had a plug in it. So I’m venting one side of the battery.
    The Group 25 battery has larger terminals.
    I purchased the 90982-05054 positive terminal from Toyota. (A dealer near me had a 15% discount.)
    I purchased the Everstart LF15-4-77 4-Gauge 15” Top Post ground cable from Walmart.
    There are three bolts that hold the battery tray in. One of them is really hard to get at with a standard crescent wrench. I borrowed a ratcheting wrench (10mm I think). A socket wrench would also work.
    I didn’t drill the hole the instructions suggested. (I didn’t have a drill.) The Group 25 battery fits snugly. I felt the battery hold down bar held the battery securely enough even with one of the bolts missing.
    I didn’t have a battery charger to keep the electronics alive while I changed the battery. My settings were long gone ...
    A big shout out to cproaudio for shining a light on the path. I never would have found my way without you.
  7. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    FYI - Check stock at Rural King online before you go to the store. The group 25 battery appears to be out-of-stock nearly everywhere. I'll probably go and pick-up the Bosch from Pep boys instead.
    EDIT: It appears that the group 25 AGM isn't available anywhere right now.
    #47 mrstop, Feb 24, 2018
  8. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Can some of the folks with bigger battery comment on your experiences?
    No one has really confirmed my observations of more ICE down time during stops and go's. thx.
    FYI - a better detail comparison of Group 25 bigger battery from the two sites.
    Bosch Platinum Series AGM Battery Group, Size 25
    BCI #25
    Cold Cranking Amps (CCA) @ 0F650
    Reserve Capacity (minutes) 110
    Weight (lbs) 37.0
    Length (in.) 9.06
    Width (in.) 6.93
    Height (in.) 8.87
    Cranking Amps @ 32F780
    Battery TypeAGM
    Right Or Left Hand PositiveLeft
    Terminal TypeT
    $142.00 2/25/18 Pep Boys Available
    Rural King Automotive AGM Group 25 Battery RK-AGM25
    Group Size 25
    Part Number RK-AGM25
    Cold Cranking (CCA) at 0°F 650
    Reserve Capacity (MINUTES) @ 25A 110
    Weight (lbs) 41 lb
    Lenth (in.) 9 1/16"
    Width (in.) 6 5/8"
    Height (in.) 8 5/8"
    Ah Cap. @ 20hr 53
    Battery Terminal Type A
    $125.00 2/25/18 sold out now Rural King Automotive
    #48 rrg, Feb 25, 2018
  9. cproaudio
    2,401
    762
    CA
    Rural King's AGM battery may not be the deal like it was when I bought my battery. I just checked their site and now it requires $12 core charge. This brings the cost to $142. I remember a year after I got my battery, Rural King stopped shipping batteries. They changed it to store pick up only. Now they're shipping them. Anyways, Pepboys always have 20-25% off on batteries if bought online and pick up in store.
  10. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    For some reason, I can't get either Rural King nor Pep Boys to allow me to order for shipment or store pickup. I have spot-checked different areas of the country with no luck. I can't find stock under the Exide brand either. It leads me to believe Exide is either back-ordered nationally on the Group 25 or has discontinued it.
    If that is the case, it looks like we are left with Optima or Odyssey on the Group 25 size. Alternatively, we go with the stock but lower ah battery. In quickly looking at other battery sizes, as you found, there aren't really any other alternatives to Group 25 which fit and give a good ah boost over stock.
  11. topshot
    topshot Member
    154
    58
    Midwest
    2015 Prius c
    What did you end up going with?
  12. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    • I haven't done anything yet. My original battery is still functioning although I suspect it is weakening (lower MPG) and I'm looking to preemptively replace before it goes bad. I like the idea of the group 25 replacement and I'm have been hoping something would show back up from Exide. However, it looks like I need to go a different route.
  13. Mendel Leisk
    42,365
    I don't fully understand: they won't sell you a battery, or you just can't order it online? Is there any problem just walking into one of their stores?
  14. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    To clarify, it is not in store (checked by walking in) or available to order online. For all I can tell, it has been discontinued by Exide.
  15. Diemaster
    Diemaster Active Member
    302
    265
    so. cal
    i would eventually like to do something similar in my prime. i use the bluetooth to netflix and chill while at work at lunch, sometimes make calls or listen to hypnosis before or after work (stress management [and no im not driving:p]) Too bad it has the battery under the hood now. i wanted to install a small\medium (less than 500w) sound system and firewalls are a bitch to get wire though.
  16. cproaudio
    2,401
    762
    CA
    Another possible option is the group 86 or 75/86. However, this battery might not be as good of option as group 25 due to cost, size and capacity. It is a bit weaker than group 25. The height is over 1/2 inch shorter than group 25 so might have to add a spacer. For that money, the best option would be the Odyssey 25-PC1400T. It packs more power than the conventional group 24F AGM into a group 25 body. I have emailed Odyssey about the lack of vent and the safety of in cabin mounting. They said the their batteries are designed to be able to mount inside the cabin even without vent.
    It looks like the days with cheap group 25 AGM upgrades might be over. I'm so glad I did the upgrade when I had the chance.
    Please keep looking. You might find something I've overlooked.
    Grit likes this.
  17. bobzchemist
    507
    342
    Grit likes this.
  18. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    I wish that would work and tried to get it. The battery shows as "not in available" online and you are not able to place an order. I also went into my local store and there wasn't any stock nor a shelf location for the battery. All signs are pointing to Exide discontinuing the battery.
  19. bobzchemist
    507
    342
    bzbee likes this.
  20. tangerino
    tangerino Junior Member
    82
    16
    WA
    I saw this was posted in the Gen 3 forums, but it sounds like it's possible to do it in other Prii. Has anyone done this for the Gen 2 that can verify?
