Replace OEM 12V battery with Group 25 AGM
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cproaudio, Jul 9, 2015.
  1. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    That's because it is actually SEALED up to some preset "pop off" pressure which should never be reached in normal use.
    The vent tube is overkill.
    THEN.....the electronics that Harbor Freight sells is cheap Chinese JUNK.
    I would never buy any of it, except for the little red multi-meter for $7 that seems to work quite good.
    That includes batteries.
    Especially one of lower capacity than the original.
    Overall a VERY bad plan, in my opinion.
    C Wagner likes this.
  2. C Wagner
    C Wagner Member
    183
    60
    Boston
    Actually, the little red HF multimeter isn't that good - I only found this out when doing the hybrid HV battery rebuild and balance. It's off vs a couple of more expensive meters I checked it with by xx tenths of a volt. It didn't matter once I knew that, but it was important to know for the max discharge and charge voltage points. As it happened the module charger itself was off too!
  3. sam spade 2
    7,035
    2,804
    2017 Prius c
    I'm sure that their "quality control" isn't that good overall but...........
    I'm on about my tenth one now and haven't found that problem with any of them.
    I presently have: one at home. One in each car. One in my Spyder. One in my fishing cabin and one on the boat.
    But I seldom use it for anything except checking the "automotive" batteries and flashlight cells.
    At $7 each, the 6 I presently have cost me about $42. Less than one "good" meter.......and I don't have the problem of needing a meter at one place and having it BE at another.
  4. C Wagner
    C Wagner Member
    183
    60
    Boston
    I think all of those HF meters were free when I got them, with coupon. Alas, now they are charging for them...
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    id love to see that under many cycles with engine always off does to the life span of the 12v bat.
  6. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
  7. C Wagner
    C Wagner Member
    183
    60
    Boston
    Yes, it will be interesting to see. I note that the OEM battery for non-SKS is 35AH also, so this kludge is not so much an under powered kludge as a size/post one. I ordered U1-SAE adapters from ebay and a special JIS to SAE adapter for the car-side connector (why did Toyota use JIS on US priuses and SAE on Japanese priuses, as I've been told???) The major impediment to my new battery from Harbor Freight is that they are holding back the 20% coupons these days, it's cold outside in Boston and the old OEM 2012 battery is holding at about 11.8 in these March temps!
  8. Joele3
    Joele3 Active Member
    137
    205
    Bay Area
    Fits like a glove. Going on 7 years on OEM battery. I'm running two amplifiers, wanted to throw in a larger battery. Thanks for the info on this thread. I ordered the adapters on ebay. I noticed sometimes my car wouldn't shut off. ICE would always stay idling until I would turn off the car. I read on another thread replacing the battery fixed it. So far I haven't noticed it doing the same thing. Up next is new struts or coils. So hard to find parts in stock for the V.
  9. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    I'm working with a few vendors, they have springs for the V, not lowering but heavy duty ones that can provide lift if you want.
  10. C Wagner
    C Wagner Member
    183
    60
    Boston
    I wanted to update those lurking and the future thread readers, that I did go buy a 35AH AGM battery and have installed it - and after a couple of days and some cornering, it's still great.
    I'd read here that a 35AH AGM SLA (unvented though) would be fine. I noted that the non-SKS cars used a battery of about the same size. I resolved to turn off SKS if I go away on long vacations. I also noted that some have said the official 45AH OEM battery costs about $250 (you install) at my dealer and the 35AH battery was sometimes available at about 1/4 that price, so even if the battery lasted not so long, due to SKS drain it a few too many times, it would probably be worth trying.
    I waited desperately for a Harbor Freight coupon and planned to buy a battery that used to be a better price but is now $75. No 20% - after waiting a long time, ... I bought a Mighty Max from Ebay for about $60 delivered. It seems good.
    A conversion was needed. I had to seek out a priuschat aficionado who sold me a small part that changes the car's terminal clamps from JIS to SAE (US standard). $20 I also needed tab to post adapters. Those were $10 on Ebay for U1 to SAE. Don't overtighten, or your tabs will rotate! Anyway, after those modifications, the new little battery went in to the place where the big battery was before. It was shimmed so it doesn't slosh around and will stay clamped down.
    The immediate thing I noticed, vs an 8 year old OEM battery that couldn't really hold a charge, is that it seemed MPG is 2-3 higher. My test wasn't scientific, but might be even better as I had been driving mostly without A/C or heat and without headlights during day. On the day I drove the car 200 miles, mostly highway, on a stretch I'd driven a few weeks ago with the old battery, I used the A/C, heat and headlights most of the time -- and got the 2-3 mpg higher.
    I may work on figuring out where to drill a hole in the Mighty Max battery to attach the car's vent pipe, but I'll probably do this after the MM battery warranty is over...
    tangerino likes this.
  11. bzbee
    bzbee Junior Member
    37
    24
    Bought a 2011 Prius a couple of weeks back. Battery was showing 12.4V resting voltage at the charge points under the hood. So decided to pull out the battery and see how old it is.
    The battery is branded "Precision Parts" - seems to be store brand of AutoNation, https://www.autonation.com/promos/batteries
    It is a Group 51 lead acid (wet) battery with the SAE battery posts filed/chopped all around to make it fit the smaller JIS connectors on the Prius (wish I took some pics before I put it back in). The stamp on the battery is 9EJ231323, the '9E' I think means 2019-May as the manufacture date. With overnight charging with a trickle charger (like Battery Tender), it came to 13.2V so I think it is decent shape, but I am uncomfortable with how it is installed.
    I've am considering upgrading to a Group 25 AGM battery for the additional capacity, but there seems to be only one option available to me locally: the Champion AGM battery (Part # 25-550CHAGM) for $187 + taxes at Pepboys.
    Everyone seems to be carrying only the flooded lead acid batteries or the Optima AGM which I don't want. Unfortunately no Rural King here in Texas. So, are there any online options for purchasing a Group 25 AGM battery at a decent price, the ones I found on Amazon or all over $200.
    Or maybe I should consider one of those Deep Cycle AGM batteries for mobility scooters. Saw a forum thread on that too.
  12. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    My battery chargers all have separate settings for Deep Cycle batteries: different charge requirements.
  13. Markee
    Markee Member
    336
    South Florida Broward County
    I just replaced mine I used a Genuine Toyota TrueStart replacement battery Part number 0054421171325
    You can find them online for around $200
  14. rrg1234
    rrg1234 Junior Member
    New Jersey
    For those of you who did the AGM25 battery here, I just replaced my old one (2015) with a Walmart:
    EverStart Plus Lead Acid Automotive Battery, Group Size 25-3 (12 Volt/550 CCA) for $ 99.75.
    It's a direct fit and no modifications are needed. My car now has 212,000 miles.
    #94 rrg1234, Jun 11, 2022
  15. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    You don't want to use a lead acid battery due to the off gassing inside the car. I would return it and get the proper AGM battery.
    Mr.Greenjeans and topshot like this.
  16. rrg1234
    New Jersey
    Ohh, Good call, I just googled it. I'm off to pep boys they got an AGM.
    topshot likes this.
  17. NewHybridOwner
    607
    283
    W. Michigan
    But an AGM battery still needs a vent connection like the OEM one. Does the Pep Boys one have a vent?
  18. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
  19. C Wagner
    C Wagner Member
    183
    60
    Boston
    Why not just keep using the supplied battery until you either notice low voltage or the car's mpg drops due to the ICE coming on more often to top up the failing lead 12v battery? After buying my DIY 35 AH AGM battery, I pulled it out and put the OEM (2012!) battery back in, which I desulfated for 6 months or so. My 'at the front of the car' / cig lighter voltage is also about 12.2-4 after sitting a day or two, ICE isn't coming on. Don't replace if you don't have to...
    CR94 likes this.
  20. NewHybridOwner
    607
    283
    W. Michigan
    I can't say that I ever been particularly aware of my ICE coming on. Sitting at a long red light today, with the traction battery about half full, and with the 12V battery at 12.2V the last time I checked, I saw no sign of the ICE coming on to top it up.
