Replace OEM battery before doing plug-in conversion?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by boone, Oct 4, 2012.
  1. boone
    boone Junior Member
    Charlottesville, VA
    Of the many questions I have regarding plug-in conversions, the first regards the OEM battery. Are folks replacing this first? I have 150k miles on my '05. I seem to be noticing that the battery (as indicated by the MFD) doesn't hold a charge as well as originally, so it seems likely it may need replacement before long. Seems to make sense to replace it (if needed) before doing the conversion. All thoughts and feedback appreciated.
    Edit - didn't get this posted all the way into Plug-in Modifications as intended. Sorry. Can't see how to move it. Perhaps a moderator can move it? Thanks!
  2. pjc
    pjc Member
    139
    46
    Bloomington, MN
    I would say it depends on what type of conversion you plan on doing. Connect the PHEV battery in parallel with the OEM using contactors (like Plugin Supply)? Or by using a DC-DC converter (Enginer)?
  3. boone
    boone Junior Member
    Charlottesville, VA
    Well, I'm leaning toward PIS, but still undecided. I'm nothing near an EE, (my nephew will be doing the install) so can you tell me more about the distinction you are drawing? My question really is how much more work the conversion kit creates if one then has to replace the OEM battery after the conversion. Thanks.
  4. pjc
    pjc Member
    139
    46
    Bloomington, MN
    Enginer works by supplying a trickle charge to the OEM battery. Therefore, you are still relying on the OEM for most of your power. If your OEM battery is weak, the benefits of the PHEV will be worse. However, with the PIS method, you draw power directly from the PHEV pack when it is needed. I would think that the OEM battery condition is much less important, then.
    Hopefully someone with direct experience with PIS will chime in, but I don't think the PHEV pack would make replacing the OEM battery much more complicated than normal. Certainly not with Enginer (it is just two wires that connect to the OEM battery). If you had someone else replace the OEM, though, they would have to know how to deal with the PHEV (or you would have to do that part).
  5. boone
    boone Junior Member
    Charlottesville, VA
    That's helpful, thanks, pjc. Any other insights, anyone else?
  6. wb9k
    wb9k 09 Gen II Prius w Hymotion Plug-In Batt
    174
    99
    Commerce, MI, USA
    I have a Hymotion plug-in conversion module in my '09, which I installed with help from a friend. That's a 5 kW battery that takes up the spare tire well. It's presence makes accessing the OEM battery just slightly more difficult, not really a big deal at all, IMO. Hope that helps....
    dh
  7. bisco
    52,905
    you may want to replace your 12v if you haven't already done so. a weak 12v can deplete your hybrid battery.
  8. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    I'd replace it with a optima yellow top or other performance 12V battery rather than an OEM replacement. I did mine myself, took about 45 minutes to remove the OEM battery, install my yellow top and put the interior trunk (boot) panels back together.
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    why an optima? and why the yellow? my 04 12v is oe, and i think its dying. i'll use the optima if there is any mileage benefit.
  10. Daves09prius
    680
    161
    Gettysburg, PA
    Optima batteries are sealed, deep cycle, shock resistant, and have absorbed glass mat rather than the liquid filled lead plates. DS46B24R YELLOWTOP® Prius® Auxiliary Battery 8171-767 :: OPTIMA® Batteries
    Here's a prius chat thread: Optima vs. OEM 28800-21171 | PriusChat
    From Clevland, posted on: optima vs oem battery - BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3)
    "Do yourself a favor and buy an optima "yellow top" battery and be happy. It's the best of both worlds: A starting battery & A deep cycle battery. It can withstand much more vibration and current draw than the standard factory battery that comes with the car. It's the latest in battery technology: absorbed glass mat (AGM) cells. These are the best because they are totally sealed, can bemounted even upside down (if you so desire) and they can come back to full strength from even almost total discharge. It also recovers quickly reducing the strain on your alternator. The factory battery cannot do any of these things. The yellow top is available [for the Prius!]...Optima batteries are very stout for their size and should give you years of trouble free service. [​IMG]"
  11. 69shovlhed
    2,170
    752
    Delaware
    cleveland sounds like he works for optima...
    i went ahead and bought the optima, cause i been using the red tops in my chevelle, and i like em. but the factory battery lasted almost 9 years; that's a personal record. i was wondering if ultimately there is any real benefit. since i made the mistake of ordering it from advance, of course when i went there to pick it up the next day they didn't have the correct battery. and of course they never even checked to see if they had it so they could order it if it wasn't in stock like the website said it was. so i had to get a battery w/ normal posts, and a marine + clamp to make it fit. the silver lining is now if i do need a battery in a pinch, a 51 series will fit.
    i think the car was actually getting kinda "lazy". locks seem to actuate a bit qicker now, that kind of stuff. tested the old battery @ 11.6V. midtronics tester didn't pass it but i tested it @ 300 CCA. later i found out it should have been tested @ 361 CCA.
  12. Daves09prius
    680
    161
    Gettysburg, PA
    When I installed my yellow top, my thermos coolant pump started working again and my dash lights were brighter. My gas mileage did improve after I replaced the battery with the optima.
  13. bisco
    52,905
    i got 8 years out of my oe battery, but i think the quality has gone downhill as there seem to be a lot more failures in the gen III batteries at 1,2 and 3 years old. i think i would use the optima if i needed one, but you have to be careful who you buy from and make sure it is charged up before installing.
  14. 69shovlhed
    2,170
    752
    Delaware
    i think any new battery would have helped if the old one was dying. but i've never liked exide batteries, or any of the may-pop batteries they sell at most parts stores, so i figured the optima would be a good choice. i'm not sure if my mileage has improved. and, i suspect they've started pumping the winter blended fuel. my mileage always drops about 5 mpg in the winter, possibly due to the winter blend. so i was thinking, would higher octane fuel help to counteract the lousy winter fuel? i'll need to check the owner's manual about fuel.
  15. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    The OP was questioning whether or not to replace the OEM HV traction battery not the aux battery. I wish they had been clearer on this since the Optima choir is singing again - for the wrong reason. Stick to the topic.
    If the OP is going to spend $$$$$$$$$ on a plug in conversion on an "old" car, he/she should definitely replace the OEM HV traction battery with a factory new one since few have the knowledge/skill to eliminate the OEM HV traction battery entirely and replace it with a custom lithium ion pack.
  16. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    No higher octane fuel will have the reverse effect stick with the correct grade.
    Exide make a very good direct fit battery for the Prius and it is a deep discharge AGM battery with a higher amp/hr capacity than the Optima or the OEM battery at about $160. Made in Chicago I believe part number FP-AGM51JIS with 4 year full replacement guarantee.
    I have no affiliation with any battery company.
  17. Britprius
    5,194
    1,924
    The yellow top is not the recommended battery for starting use this should be a red top.
  18. 69shovlhed
    2,170
    752
    Delaware
    perhaps exide makes good AGM batteries, but their lead acid batteries used to suck.
    why would higher octane fuel decrease mileage? keep in mind the USA winter blend petrol is really lousy gas.
  19. Britprius
    5,194
    1,924
    High octane fuel has fewer calories ( the amount of energy stored in a given amount of fuel). This also applies to so called winter blend fuel.
  20. Daves09prius
    680
    161
    Gettysburg, PA
    Does Optima make a red top for a Prius? Why the red top vs the yellow top? When you search for a battery on the Optima website they show the yellow top Pt# 8171-767 DS46B24R Prius Auxiliary.
    What red top model number fits the Prius?
