Replace Oil Drain Pan
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cgm55082, Jul 13, 2013.
  1. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Maybe, you are quoting a person who has been banned from the PC. Do you realize you are quoting a comment from 2013?
    Skibob likes this.
  2. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Holy $#!s*(................no wonder..!! LoL
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    The method of rethreading the welded on nut of the oil pan has to be as good as or even better than a complete new oil pan. In the manufacturing process nuts are tapped with robotic machines in the same was as one would tap the hole with a hand tap. Only outside threads are mechanically rolled.
    The M14 tapped hole as opposed to the M12 of the original and the accompanying M14 plug makes the new unit even stronger than OEM. The 1.5 mm coarser thread pitch as opposed to the original M 1.25 metric fine thread pitch is less likely to be cross thread.
    My thoughts based on my engineering experience.
    Montgomery and Mendel Leisk like this.
