Replace one bad block?
Discussion in 'Gen 3 Prius Technical Discussion' started by PRI6080, Jul 19, 2022.
  1. PRI6080
    PRI6080 Junior Member
    22
    Hey guys. I own a 2010 Generation 3 Prius with about 170,000 miles on it. I got the dreaded c"heck hybrid system" message that came up and from using doctor Prius, it turns out one of the blocks for the whole pack is bad. My question is this: can one change just one block get away with it?(matching wise) I really don't want to buy a whole pack right now and just figured I could change the one block and if it lasted me a year or two I'd be fine with that.
  2. JC91006
    16,939
    8,647
    You can change the failed module but changing just the module won't get you a reliable repair. If you plan on keeping this car for 1 or 2 years, you would start to invest some time and money into this car for it to be reliable.
    First thing you should do after the battery repair/replacement will be to clean out the EGR circuit and Intake manifold. These areas are the leading cause to the head gasket failing on these cars at your mileage. It's a lot of work (time wise) but without doing it, you'll end up with a real big $3000+ headache when the head gasket fails.
    There are other items that would need attention after 12 years but you'll need to put some good money to keep this car running reliably. Spend money now for maintenance or spend a lot more money later.
  3. PRI6080
    22
    Oh, trust me, I've cleaned out the EGR system once and plan on doing it again including the spark plugs and maybe a catch can.
    #3 PRI6080, Jul 19, 2022
  4. PRI6080
    22
    Another question I have: I found a video on YouTube where a guy is able to remove a bad cell without taking the whole battery pack out of the trunk. Does anybody know if this could be done with a gen 3 prius? The video does not state what generation Prius he is working on. TIA
  5. JC91006
    16,939
    8,647
    You need to remove the battery, you don't really want to watch some crazy stuff and try following it. It's hard enough to do it out of the car....
  6. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You have to balance the pack. Prolong has a great system for this.
    You might want to try that system first. It's less costly than a whole battery.
    And if that block is "bad", you can bet others will soon follow.
    I used that Prolong system. It took 3 days for the 4 charge and 3 discharge cycles.
    If I could have monitored it better it would have been less time. But it really made a difference.
    It lasted about 9 or 10 months before I noticed it slowly started the slower charge quicker discharges.
    I just did a full charge, because of time, and it's been working well since.
  7. PRI6080
    22
    Did you have to buy this unit? It looks like there's a charger and a discharger. Sounds kind of expensive. Or did you take it somewhere to get this service performed?
  8. ASRDogman
    8,070
    4,092
    I purchased it. It has the discharge and charger. And well worth the money.
    It was around $700. A lot less than a new battery.
    There are people out there will all kinds of time on there hand, and probably a spare battery.
    They spend weeks and week charging and discharging individual batteries, then paring them,
    then "balancing" them. If you have a month or so to do this, and spend the money on all the
    chargers, it's probably less costly. But labor wise it's not. A lot of work taking that battery assembly
    out of the car and then putting it back in. And then taking it apart, and putting back together again???
    Unless you like doing it.....
    Depending on where you are, there might be someone that would rent it to you. You'll have to
    purchase the harness, about $150, and install it. Which is not hard to do.
    I believe you can find new cells for around $50, used less, but who knows what you'll get with used?
    For me, there are certain things that are just not worth the risk of buying used. Batteries of any kind
    are one of them.
    What you might want to try is to remove the buss bars and clean them up. And the battery contacts.
    Just be careful NOT to short them! If they are corroided, it will create resistance.
  9. PRI6080
    22
    Thank you. Lots of good information you provided. I didn't know they sold individual modules as new. Thought only used ones were available unless you bought a whole new pack.
    #9 PRI6080, Jul 20, 2022
    ASRDogman likes this.
