Replace original horn with Lexus LX600 genuine horn
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Mksky, Mar 28, 2023.
  1. Tooly
    Tooly Member
    51
    44
    Okanagan, BC
    2023 Prius Prime
    XSE
  2. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    Yeah, thanks- already bought one off Amazon, yet the ratcheting kind- will be easier to work with in tight placed. Will be delivered here tomorrow.
  3. Hamid Ali
    Hamid Ali New Member
    Los Angeles
    2023 Prius Prime
    Thank you! Just ordered it!
  4. Argyros
    275
    142
    2023 Prius
    Finally installed the Lexus dual horns! One thing to note; I have friggin big hands and had a he'll of a time getting my fingers in there to put off the connector...I wish the play from the existing connector allowed the wire to pull above the cowling...but anyways, once the old horn was put, it only took 10 mins to put the others back in and align them....what a difference! No more 'meet meep'!!!
  5. Hammersmith
    Hammersmith Senior Member
    2,500
    2,564
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm not surprised at the difficulty. The repair manual says to remove the whole front bumper cover to replace the horn. lol
    I just ordered a set of horns last week, and I plan to do that upgrade and the silencing of the UFO at the same time. And I'm not removing the bumper cover either. :LOL:
  6. Argyros
    275
    142
    2023 Prius
    Good luck to you Hammersmith! I actually LIKE the UFO sound. Tonight, when exiting a parking spot, a couple was in front of us, and they both smiled at us when I put Agyros in reverse!
  7. Mntlkaos
    Mntlkaos New Member
    St. Louis, MO
    2023 Prius
    Replaced the horns today with the Lexus ones and it took 30 minutes maybe. No drilling, no splicing, nothing. Took the cover off under the hood, took the old horn off, added the two horns to the spots where they are meant to be added. Zip tied them longer cord to make it clean. Replaced the cover. Shut the hood then I got horny…my neighbors were probably wondering why I kept blowing the horn. Easy peasy.
    theRob, Argyros and otatrant like this.
  8. Argyros
    275
    142
    2023 Prius
    Congrats Mntlkaos! I feel much more confident with the louder dual horn when I'm in traffic!
    #48 Argyros, Nov 19, 2023
    Mntlkaos likes this.
  9. Mntlkaos
    Mntlkaos New Member
    St. Louis, MO
    2023 Prius
    I know!
  10. Alan Nomoto
    Alan Nomoto Junior Member
    Seattle
    2023 Prius
    Just installed a pair of aftermarket Mitsuba 440/550 hz horns I picked up in an auto parts store in Tokyo. Just used spade connectors including into the fuse side factory connector. Vast improvement & louder than my scooter now!
    Blackat likes this.
  11. hyperphil
    hyperphil Junior Member
    PA
    2024 Prius
    Limited AWD-e
    Did you guys need to disconnect the battery before disconnecting the horns? I noticed the instructions suggest it but don't know if it's necessary
  12. hyperphil
    PA
    2024 Prius
    Limited AWD-e
    Update - just finished upgrading my horns. No need to disconnect battery. Simple plug n play as mentioned. Only catch is I had to re-install my horns after reviewing the photos in this thread so they faced each other. Not sure if this matters though.
  13. stuyguy
    stuyguy Active Member
    170
    134
    Lakewood, CO
    2024 Prius Prime
    XSE
    I installed the dual Lexus horns today without disconnecting the battery; no problems. And what a difference!
  14. Argyros
    275
    142
    2023 Prius
    Didn't disconnect the battery on mine either- only disconnected the plugs and used the socket to undo the stock horn, then first plugged in, then attached the right horn (if looking from the front of the car), which is where the EOM was, then after, plugged in the left horn, and attached that as well. No need to zip tie the wires. They are well out of the way of any moving engine bay items.
    hyperphil likes this.
  15. Mr.Vanvandenburg
    1,362
    668
    2020 Prius Prime
    I put the horns in, and only needed the horns, none of the other stuff in the box. I got Toyota Premium horns on ebay. Came from Japan. Made in Japan.
    Seeing how easy I bought another set of horns for $15 on Amazon to use on a 96 Toyota truck. It uses the same connector as the 2020 Prime. Same type of mounting bolt. These are made in China. Great upgrades.
    No need to disconnect battery if using the old connectors.
    caymandiver75 likes this.
  16. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    It doesn't matter which way the horns face, inward or outward, just that the opening faces downward so water can't collect in there.
    SM-G781V ?
  17. BacknBlack
    BacknBlack Junior Member
    24
    22
    2023 Prius
    This is a very worthy/recommended upgrade! Easy installation!
    theRob likes this.
  18. Mksky
    Mksky Member
    61
    35
    Los Angeles
    2024 Prius
    I just got the horn today and wanted to adjust the bracket of the horn on the back but I wasn't able to. Does anyone know how to unscrew the bolt on the back of the horn?
  19. wrtboy168
    wrtboy168 Member
    70
    29
    Northern California, USA
    2024 Prius
    hmm... found the 5th gen prius on the chilton library. torque spec for the horn bolt is 14 lbf·ft. hope some may find this info helpful.
  20. Mr.Vanvandenburg
    1,362
    668
    2020 Prius Prime
    Use an open end or crescent wrench as the nut is shallow. Some sockets or box end wrenches have too deep of a chamfer on the opening. Mine did work. Hold the inner screw from turning with a philips as you are loosening the nut.
