replace shocks/struts?
Discussion in 'Generation 1 Prius Discussion' started by jhknight, Mar 28, 2012.
  1. Patrick Wong
    18,210
    6,514
    What is the problem - is the manifold developing a crack, or ??
  2. PriusTech
    PriusTech Active Member
    264
    122
    Reno
    Pretty common for aftermarket struts to have a higher pressure gas charge. I've run into this problem replacing just the fronts. It raises the front higher than the rear.
  3. PriusTech
    264
    122
    Reno
    The plastic intake is shrinking in the cold and it develops a vacuum leak. It manifests as a clatter on cold start. The damper plate is rattling because the ICE is not starting right away. At first they were replacing just the gasket, now it's the gasket and manifold. Only happens when you get below about 25 deg F for a low.
    Patrick Wong likes this.
  4. Patrick Wong
    18,210
    6,514
    When you say "2nd gen", are you referring to the 2004-2009 model year Prius; or the 2010-current model year Prius?
    Since you are talking about a "plastic intake", I assume that you are not referring to the 1.5L Prius (2001-2009) engine which has an aluminum intake manifold. The only plastic intake part that I recall is the air cleaner housing...
  5. PriusTech
    264
    122
    Reno
    my mistake, it is the 3rd gen
  6. Patrick Wong
    18,210
    6,514
  7. Charlie5280
    Charlie5280 New Member
    16
    2014 Chevy Volt
    90k miles for shocks and struts is pretty typical.
  8. PriusTech
    264
    122
    Reno
    Not for any Toyota I've seen.
  9. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    So for those who are replacing struts are they only replacing the strut mounts and bearings also? My 2002 Prius with 143,000 rolls like a boat and clunks on bumps and pretty much rides terrible. My thoughts without actually getting under and checking all the components were that the struts are toast. Are there other suspension components that people are also replacing like control arm bushings or ball joints? I would get under and look but it has been extremely cold.
    TomK
  10. Patrick Wong
    18,210
    6,514
    I would replace the struts and the strut mounts as well as the rubber "spring insulators" that sit above and below the coil springs. The insulator above the coil spring also serves as the pleated rubber cover.
  11. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    So pretty much replacing the entire strut assembly except the bearing?
    TomK
  12. Patrick Wong
    18,210
    6,514
    The top strut mount includes the bearing that allows the top of the strut to pivot.
  13. alekska
    alekska Active Member
    435
    138
    Atl
    + on that. I have replaced fronts with KYB, together with top mounts at 110k miles. I have replaced rears with OEM - had no problems ordering them. Car drives like new now. No bouncing.
    - Alex
  14. DaveGoodrich
    DaveGoodrich Member
    141
    68
    Are the strut mounts a dealer-only item, or are they available aftermarket like the kyb struts.
    SM-N900V ?
  15. alekska
    435
    138
    Atl
    For Gen 2 you can probably find them at non-dealer . I use Rockauto.com for many years. I'm not associated with them, just customer. But, personally, for item like a mount I would go with one of the online Dealer part stores.
    - Alex
  16. Patrick Wong
    18,210
    6,514
    I also would buy the correct Toyota parts, when it comes to the strut mount and the rubber spring insulators. If you want to buy aftermarket KYB instead of the Toyota-branded KYB struts and shocks, that's up to you.
  17. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    So the only part that is reused is the spring right?
    TomK
  18. Patrick Wong
    18,210
    6,514
    Yes
  19. Charlie5280
    16
    2014 Chevy Volt
    I could see that in Seattle. Here in Denver/Wyoming, where we see on many days as much as a 60degree Farhenheit temp swings, are roads are utter garbage.
    I could see getting 130k+ out near you in Seattle....but here that is a TALL order when many guys I know with 18" tires and 45 series profile wheels have to pray not to replace them from a sidewall puncture due to our potholes :(
  20. bigbearballs
    bigbearballs Junior Member
    57
    Austin, TX
    Lots of mixed answers in here, I have a prius gen 2 with 171k on it. I took it into firestone yesterday and they wanted $1500 to replace the back and front struts and shocks. He showed me cupping on the back wheel but I do over inflate my tires and never get the car aligned. The rubber spring insulator was pretty destroyed on the front shock also. What do you think? I don't see having this car more than 2 more years. Is it worth it?
