Replace the rubber steering wheel buttons?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by clangjr, Jun 24, 2013.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    I was stunned when I saw this thread a couple of days ago, since I had long given up on the appearance and feel of my left buttons on my 2010. I was convinced they were rotting away. I had no idea, they were just gummed up. I took a couple of alcohol pads to them, and in about 5 minutes, they looked factory fresh. Thanks all.:)
    ASRDogman and Prius_Angie like this.
  2. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    Alcohol can dry them out. Warm soapy water, or Totally Awesome would be better.
    But as long as they are clean! :)
    #22 ASRDogman, Aug 1, 2020
    Prius_Angie likes this.
  3. lenjack
    804
    114
    Pennsylvania USA
    Thanks...I'll do that for maintenance.
  4. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    @MagnusAG99, could you post pictures of your black controls post-installation? With the button layout having changed in the replacement, did you need any modifications to get the controls to operate correctly?
    The media control buttons were sticky on my 2010 as well, and on closer inspection I see they're actually torn. Replacement, either of the rubber pad alone from a salvage yard or of the whole assembly from an aftermarket source seem to be the only options.
  5. AzusaPrius
    AzusaPrius Senior Member
    2,257
    942
  6. kungfuaddict
    kungfuaddict Junior Member
    Tampa, FL
    Hiya - I had tried cleaning my control buttons as suggested in other posts. Unfortunately, I put hand sanitizer soaked hands on them last year and they (and the steering wheel) started falling apart. Anyways, I just received some replacement buttons from AliExpress. I'd love to know HOW you changed the buttons. Can you just pop them out, or do you have to take apart the assembly?
  7. Mr. F
    Mr. F Active Member
    390
    264
    Washington
    You'll need to take off the entire assembly including the steering wheel airbag. Make sure you disconnect the 12V battery before proceeding with the job.
  8. kungfuaddict
    Tampa, FL
    Oh man. OK. Thanks! I had just removed the wheel to put on a hand sewn steering wheel cover. It's not a custom fit one. :-( So, here come the scissors and me ordering a custom fit cover!
  9. 134HP Bard Womyn Magnet
    103
    28
    NYC
    Can you link to the ones you bought? I haven't looked in a bit but only found Gen2 ones a month or so ago. Also a follow-up report after install (for fitment and function) would be great.
  10. kungfuaddict
    Tampa, FL
    Well, I would post the link, but the forum is blocking me because I don't have 4 posts yet. LOL I'll link them as soon as I can..... I haven't installed them yet, but plan on doing that sometime next week. They appear to be an exact match and good quality -
    I've gotten a ton of stuff recently to "upgrade" my Prius as I plan on keeping it for another few years - at least until I get my new Aptera Noir - I know this is a Prius forum but I have to plug it! Anyways, getting an Android touch screen head unit w/ Android Auto/Carplay, backup camera & forward camera, active TPMS, remote start, neoprene seat covers, floor mats, antenna, all LED interior, headlight, turn signal, backup lights, and now a custom fit steering wheel cover... I went a bit crazy with it all honestly, but should help it feel "new" again
  11. Kushuk
    Kushuk Junior Member
    Virginia
    I just finished installing a replacement set of rubber buttons on my 2010 Prius (volume on the left and trip on the right) that I picked up from a Chinese eBay seller for about $12.71 plus tax, shipped free (ebay link /itm/296417902126). They arrived in a little over a week. I was able to follow the youtube walkthrough video titled "Prius Steering Wheel Radio Controller Repair - How to Remove and Replace". That video only showcases replacing the left (volume) rubber controls, but the instructions are nearly identical for the right (trip) controls. I found that I didn't have to snip the ziptie on the left, but I did have to snip it on the right. That was because the wiring harness was removable on the left, but not on the right - I tried pretty hard to do so, until I realized that I might just end up breaking it.
    The look and feel are fantastic and seem to be either a perfect match to OEM or as close as you could hope for. The backlight shines through clearly in the dark. The only difference I could tell was that it was a new button and wasn't quite as broken in as my 15 year old ones. The old ones also felt slicker, similarly to how a rubber eraser might get slicker as it ages. The new ones had a pleasant new rubber feel that will likely also age similarly to the OEM. Overall, I'm really happy with the swap.
    Melthias and ASRDogman like this.
  12. Purrius
    Purrius Member
    172
    50
    Northeastern US
    I'm replacing mine right now and found this thread searching for a good tutorial. Pretty impressive it's still alive and kicking after over a decade. :D
    I was able to pull the old one out of the left side without removing the steering wheel or any of the trim. However, I'm unsure if I'll be able to install the new one without pulling the silver trim off.
    I've got the new one seated, but it's not completely flush due to being unable to hook the holes on the tabs properly under the silver trim.
    (Oh yeah, these are the exact ones I ordered from AliExpress.)
