Replace Tran fluid
Discussion in 'Gen 2 Prius Main Forum' started by Ernie stires, Jan 22, 2023.
  1. nemebean
    nemebean Junior Member
    42
    28
    The transmission takes 4 qts, but unless you tear it apart to get every last drop out you'll never put that much back in during a change, IIRC. Even with pulling the drain plug there's some leftover. I say this mostly so no one panics if they can't get a full 4 qts back in before it starts spilling out.
    If you can't physically get under the car (I drove it up on 4 pieces of 2x lumber and it gave me just enough space, YMMV though), then I suppose the fluid extractor would be better than nothing. I'm not positive you could get at the fill plug from the top though. As I recall, I opened it from under the car and then snaked a hose connected to a funnel down from the top to actually put the fluid in. I don't think there was much space to get a wrench in there, however.
    Ernie stires likes this.
  2. Mendel Leisk
    42,271
    I know on third gen it's pretty much impossible. I'll leave a light on under the car, so I've got some idea where I'm going, then from above start snaking 3 feet of hose down in the direction of the light. It's very crowded: you push the hose through, then go back underneath, and with luck it's emerged near the transaxle fill hole.
  3. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    Sadly the physical demands have been a little too much is recent years.
    Mendel Leisk and bisco like this.
