Replace "Transmission" Fluid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Canard, Aug 21, 2016.
  1. Canard
    Canard Member
    223
    Ontario, Canada
    I've got about 200 000 km on my 2010 Gen3 Prius.
    When in for my last maintenance service, my dealership gave me the spiel that "While Toyota Canada doesn't necessarily recommend it, our dealership recommends that you change the transmission fluid on your car at this mileage."
    I questioned them on it - mentioned that the transmission setup is totally different here, with relatively few moving parts - and just got the stock response of "Well, our dealership recommends it."
    I'm curious what others' thoughts here are on this. I'm all for changing fluids when it makes sense (cheap insurance), but I'm also concerned that my dealership hasn't given me much confidence that they fully understand the differences between a hybrid and conventional ICE (I still get a chuckle out of seeing "we checked the belts" on the maintenance/service reports. Wanna point those belts out to me?).
    So... is anyone doing this?
    Thanks,
    -Iain
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I do recommend it. The failure mode for the transaxle seems to be overheating and baking the insulation off the Motor/Generators. By replacing the fluid, you remove suspended solids that may be causing short circuits and reducing fluid flow.
    As a DIY, the parts should be about $40USD, my dealer does the service for $110USD. I have no idea what your dealer charges.
    I like 50,000 km, then 150,000 km, then every 150,000 km as a service interval. So in my mind you are very ready.
    Rebound likes this.
  3. grnd0
    grnd0 Member
    42
    26
    I just did mine myself. Not a hard job at all. 2010 with 56,000 miles. Fluid
    looked really bad.
  4. Mendel Leisk
    42,347
    Well then you should be all over this: about $40 for the fluid and a couple of washers, takes about an hour to DIY. You need to raise and level the car, drain the fluid, pour in fresh fluid till it starts coming back out (a funnel with 3 foot of hose extension is simplest approach to doing this).
    Through the dealership, anywhere between $80 and $100 I wouldn't argue; any higher, I'd look into DIY, or dicker. Make VERY sure they're using Toyota ATF WS fluid. It'll take about 3.5 liters, so you need to have four on hand.
    I would have done a first drain-and-fill about 180,000 km's sooner. Then every 60.0000 km's or so, pick your interval. The first one seems to be most crucial, the fluid most dark looking.
    #4 Mendel Leisk, Aug 22, 2016
    Steph1972 and DadofHedgehog like this.
  5. nicoj36
    nicoj36 Active Member
    518
    162
    I recommend it also. There is a very easy DIY video on YouTube. You just buy the trans fluid, fluid pump, and hexagon key to open the drain bolt and fill bolt. Your car will drive like new! Might as well do the oil change altogether too.
  6. Jay168
    Jay168 Junior Member
    Portland Oregon
    Toyota says transmission fluid not need to be replaced.Is it true?
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    true. Lifetime fluid.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Every lubricant ever made needs replacing eventually. Every 100,000 miles is fine,
  9. Mendel Leisk
    42,347
    Toyota doesn’t actually say anything on the subject.
    I would change it at least once, sooner than later.
    Merkey likes this.
  10. Mendel Leisk
    42,347
    Repair manual has instructions fwiw:
    MachMarcus likes this.
  11. tony_2018
    tony_2018 Member
    227
    68
    I go by this no matter what.
    Rebound likes this.
  12. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    "Lifetime" usually means the life of the epa warranty.
    It's easy enough to change and inexpensive enough that you should do it.
    Grit likes this.
  13. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    To be accurate, what Toyota says is that you need to inspect the fluid. And you’ll find that it’s really dark and in need of replacement, so replace it. :)
  14. Justin Henderson
    Justin Henderson Junior Member
    Salt Lake City
    2014 Prius v wagon
    Do recommend replacing the fluid from the transactional as well?
    Is that an additional 4 bottles?
    mikey_t and Mendel Leisk like this.
  15. Mendel Leisk
    42,347
    There’s one “transmission”; Toyota calls it the “transaxle”. There’s a link in my signature with info on changing the fluid. If you’re on a phone turn it landscape to see signature.
  16. ChapmanF
    19,024
    A single unit that combines the speed/torque-converting "transmission" and the torque-splitting "differential and axle' is called a transaxle. That's what the Prius has, so that's what they call it.
  17. CR94
    CR94 Senior Member
    2,830
    1,243
    Northwestern S.C.
    The term "transaxle" has been used pretty much ever since front-drive cars appeared to denote the combination of transmission (of any type), final reduction gearset, and differential, all combined within a single case and sharing common lubricant. It's definitely not specific to Prii.
  18. Fifen
    Fifen Member
    77
    33
    Utah
    I just replaced my transmission fluid (155k) color of the old fluid looked like chocolate syrup. New fluid is like fruit punch red. There's no way it's lifetime
    SM-N986U ?
  19. ASRDogman
    8,066
    4,086
    "Lifetime" for care manufacturers mean the lifetime of the warranty....
  20. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I did transmission fluid replacement at 60k miles, 120k miles 180k miles and at 240k miles in my 2004 Prius. I had the old fluid lab analyzed each time. The first 60k fluid had significant silicon (from the sealant used in seams), metals (from the lapping in of the transmission gears) and had lost significant viscosity. That first change was necessary but should have been done earlier. The fluid from the later changes were in better shape so they could have been done later.
    I did an ATF fluid change in my 2016 (killed by a Kamikaze deer) and 2020 Prii before they reached 30k miles and will do it again at 120k miles and every 90k miles thereafter. My dealer charges about $100 for the job.
    JeffD
