Replace "Transmission" Fluid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Canard, Aug 21, 2016.
  1. Mendel Leisk
    42,271
    AFAIK Toyota doesn’t say “lifetime”; they just don’t say anything.
  2. Justin Henderson
    Justin Henderson Junior Member
    Salt Lake City
    2014 Prius v wagon
    So is it 4 bottles for the transmission and 4 for the trans axle?
  3. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    No, you're still confused. 3.6 quarts for the entire transaxle, which includes the transmission. There's only one fill opening and one drain opening for the entire transaxle.
  4. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    You'll "need" 4, 1 qt bottle's to fill the transmission.
    Remove the filler plug first, then the drain plug.
    It will drain in just a few seconds. Then install the drain plug.
    It's easier to get plastic tubing and run it from the top of the engine compartment
    down to the filler plug. Make sure you are on jack stands and the car is level.
    Slowly pour 3.5qts down the tube. Crawl under the car and remove the tube.
    If fluid drains out, install the filler bolt. If not add a "little" more fluid and repeat.
    When fluid runs out the filler hole, install the filler bolt.
    Put everything away, you're finished.
    Fifen likes this.
  5. Justin Henderson
    Salt Lake City
    2014 Prius v wagon
    Ok. Thanks for clarifying. I thought I had seen in a video where it two separate drain and refills.
    I don't have jack stands. Just a set of ramps. I'll ask around. Thanks!
  6. Fifen
    Fifen Member
    77
    33
    Utah
    I did it with just 2 jack stands. Rear was on the ground. Since car wasn't level I got 3qts in. I took it to a shop for them to put the last little bit in. My driveway was slightly slanted too.
    Feeding the tube from the top was easiest. But if it's just you working on it that could make a mess. Be sure to have a drain pan ready. Or get another person to help out.
    SM-N986U ?
  7. ASRDogman
    8,047
    4,078
    Ramps and two jack stands. You REALLY need it level. You left about a quart in it.
    I drive the Prius up the ramps, then I jack up the rear and lower onto the jack stands.
    But it's better than nothing. (y)
  8. Fifen
    Fifen Member
    77
    33
    Utah
    Yeah I know, which is why I took it to a shop after. I just needed it to be somewhat drivable.
    SM-N986U ?
