Replaced 12v battery and fusible link, starts once, then no more
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cacao, Jul 30, 2020.
  1. cacao
    cacao Junior Member
    38
    Ahh, but they are not tight. The shims are not allowing me to tighten up the connections very well, I think they are tight, but the next time I check, the shim has slipped and the connection is loose.
  2. ttou68
    ttou68 Active Member
    351
    211
    If that's the case then it should be taken care of before any farther diagnostic on any issues with this vehicle...
    If not, It is simply wasting everyone's time on trying help you solving any issues that may or may not exist..
    dolj likes this.
  3. cacao
    cacao Junior Member
    38
    I'm aware of that. I just discovered that the posts were slipping a couple of days ago. i have purchased new OEM clamps and will be changing things over as soon as our sad Postal service can get them to me.
    dolj likes this.
  4. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    Sounds like the shims are very poorly designed. Maybe a cut with a hacksaw might fix them.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,803
    2017 Prius c
    Well you did NOT say that before.
    Of course, that should be fixed first.
