Replaced 12v battery, still getting "Transmiss
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jdiamond, Jan 20, 2015.
  1. jdiamond
    jdiamond Junior Member
    My 2005 Prius has about 140,000 miles. I had been getting the intermittent warning message, "Caution: The transmission lock mechanism is abnormal" although the vehicle has been able to start and drive just fine. I replaced the 12v battery, which was suggested in several other threads. However, the warning keeps reappearing.
    Possibly related, my gear shift knob is "sticky". I'm able to get it into each gear (and the transmission remains in the gear selected), but the knob does not move smoothly like it used to. Any suggestions?
  2. JC91006
    16,496
    8,406
    I think it's time to replace the shifter...you can get them used on ebay
    xpcman likes this.
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    First, check the connections to the battery, including the bolt to the chassis on the negative lead. Check the voltage at the jump point under the hood while you turn on the headlights, open the doors etc. Compare that voltage to what you read right at the battery terminals. If you see much drop, then there is a poor connection somewhere. Also, new batteries are not necessarily properly charged when purchased, so make sure the battery is completely charged.
