Replaced 12v battery with Optima
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by F8L, May 2, 2009.
  1. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Yes that is correct, all accessories off too.
  2. Patrick Wong
    18,210
    6,517
    91K miles on my 2004. I decided to replace the original equipment 12V auxiliary battery today as a preventive move, as cold winter weather is approaching. This morning with temp in the high 30s F, the battery voltage was 12.2V with the car IG-OFF.
    The correct battery cost $138.70 plus tax at the parts counter of Precision Toyota of Tucson. It would have cost a few dollars more at Desert Toyota, Tucson.
    The part number is 28800-21170 and the battery was manufactured in July 2009. That part number is for 2G Prius that have Smart Entry / Smart Start. Base Prius use a smaller-sized battery. The voltage was 12.9V out of the box.
  3. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Well I got a new Optima from Amazon and immediately took it to Auto Zone to be trickle charged. They said that on their machine, it reported a reading of a 50% charge. I let it stay there for 24 hours and when picking it up, they said the reading was a bit above 100%. Installed the new battery and works flawlessly. No more flashing/dimming lights, no weird alarm chirps, and no clicking noises. Guess the old battery needed a good trickle charge before being installed.
  4. richard schumacher
    7,683
    1,066
    United States
    Thanks for the update. Apparently, unlike eLearnaid, Amazon does not charge the battery immediately before shipping.
  5. hpartsch
    hpartsch Member
    102
    pa
    Patrick, thanks to you price guidance I saved +40 bucks. I called my toyota for a replacement battery, they wanted 188. I tried calling the other toyota parts place today (its usually cheaper) for a price quote and they were closed. I called back the closer toyota and said the other one said they would sell me it for 139, could you match it. With no hesitation the guy said yes.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Good job on getting it cheaper. Patrick is a good guy to have around. ;)
  7. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Can a trickle charger be connected under the hood (relay box- just like charging the battery) while replacing the 12V so as to not lose any radio, GPS Navigation, etc. settings?
    I've heard of people using a spare battery to give the car constant juice so the settings are not lost. I would think a charger would do the same.
  8. Mendel Leisk
    42,289
    That has worked for me on previous cars. I have other chargers, but for that application used a 0.5 amp charger, originally intended for charging motorcyle batteries. All you need to accomplish is to supply enough voltage for the memories.
    In my case the battery was under the hood, and I clamped the cables to the battery cable positive lead and a ground. But I think with prius what you've described would work fine.
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    It depends on the charger. Some will click off as soon as you remove one of the terminals in the back. A jump pack works better.
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    We always used a 9v battery wired to a cigarette lighter adapter. You could just plug it into the cigarette lighter outlet and it would keep all your presets. I'm not sure if it would work on a Prius because those outlets stop supplying power when the car is off. Hmmm
  11. Agape
    Agape Member
    378
    Ireland/Eire
    Or any 2nd battery or another car with jump leads attached to the terminals while removing battery.
  12. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    I used a trickle charger when replacing the OEM 12v with an Optima yellow top...worked perfectly...no settings lost no triangle of death, etc...
  13. Aaron
    Aaron Member
    260
    Monroe, Ohio
    I do have a riding lawn mower battery. Would connecting jumper cables from that to the connection on the fuse box do the trick?
  14. Patrick Wong
    18,210
    6,517
    It would.
    Owners who use an auxiliary 12V source when replacing the 12V battery need to be very careful not to short the positive terminal to ground when removing the cables.
  15. larrydunn
    larrydunn New Member
    washington
    There is currently a direct replacement battery for optima for the prius the number is DS46B24R which requires no changes to the car. It is a direct fit. LDD:mod:
  16. BassInstinct
    BassInstinct Junior Member
    17
    Mid-Atlantic
    Just got my yellow top online direct from Optima. Couldn't be easier transaction. Does the car run better with the Optima? Could be....
  17. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    It would be nice to see some numbers from testing these Optima batteries. For example, turn the car IG-ON by pushing the power button twice without pressing on the brake. Turn the climate control fully off. Then turn the headlights on. What is the battery voltage? Then turn the rear defogger on. What is the battery voltage?
  18. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
