Replaced 12V months ago, and still get this issue from time to time
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by FlyMode, Nov 18, 2024.
  1. FlyMode
    FlyMode Junior Member
    GTA
    2018 Prius Prime
    For context my 12v was low so I replaced it because I was getting the Christmas tree effect.
    It stopped for a while but from time to time comes back and goes away. Happening more frequently. Usually I know it's going to happen when the ABS starts kicking in on light breaking. Shortly after the Christmas tree arrives.
    Dealerships are still 2-3 weeks backed up and aren't willing to really help.
    I'm just curious if there's something I can do or if someone has any idea. Attached is a few screen shots from my scanner app and a written report of everything!
    Any info helps thanks!! Screenshot_20241118_111136.jpg Screenshot_20241118_111142.jpg
    Car Scanner ELM OBD2
    Version: 1.106.0/401060/GP
    DTC report
    Connection profile: Toyota OBD-II / EOBDDate: 2024-11-18 11:11:45 AM
    VIN: JTDKARFP5J3070172
    OBD-IIOBD-II
    DTCs: 2
    C050D [0x450D]
    Status: Confirmed
    C0510 [0x4510]
    Status: Confirmed
    Engine control unit #2Engine control unit #2
    DTCs: 44
    P2610(93) [0x261093] Archive (inactive)
    Engine control module (ECM) - internal engine off timer performance
    Status: Test failed since last DTC clear
    P10AA(00) [0x10AA00]
    Status: Test not completed during this operation cycle
    P050A(00) [0x050A00]
    Idle air control (IAC) valve, cold start - performance problem
    P050B(00) [0x050B00]
    Ignition timing, cold start - performance problem
    P0125(00) [0x012500]
    Insufficient coolant temperature for closed loop fuel control
    Insufficient Engine Coolant Temperature for Closed Loop Fuel Control
    P011B(62) [0x011B62]
    Engine coolant temperature (ECT)/intake air temperature (IAT) - correlation
    P0128(00) [0x012800]
    Coolant thermostat - coolant temperature below thermostat regulating temperature
    Coolant Temperature below Thermostat Regulating Temperature
    P1420(00) [0x142000]
    Catalyst Temperature Sensor Failure
    Intake Constrictor CTRL Circuit Open or Short
    P1421(00) [0x142100]
    Catalyst Damage
    P1422(00) [0x142200]
    EGI Temperature Sensor Failure
    P1423(00) [0x142300]
    EGI Functionality Test Failed
    P2400(7E) [0x24007E]
    Evaporative emission (EVAP) leak detection pump, control - open circuit
    P2400(7F) [0x24007F]
    P2418(7E) [0x24187E]
    Evaporative emission (EVAP) switching valve - open circuit
    P2418(7F) [0x24187F]
    P043F(00) [0x043F00]
    Evaporative emission (EVAP) leak detection system reference orifice - excessive flow detected
    P043E(00) [0x043E00]
    Evaporative emission (EVAP) leak detection reference orifice - low flow
    P0441(7E) [0x04417E]
    Evaporative emission (EVAP) system - incorrect flow detected
    Evaporative Control Incorrect Flow Detected
    P0441(7F) [0x04417F]
    P2450(7E) [0x24507E]
    Evaporative emission (EVAP) switching valve - performance problem or valve stuck open
    P2451(7F) [0x24517F]
    Evaporative emission (EVAP) switching valve - valve stuck closed
    P1450(2A) [0x14502A]
    Unable To Bleed Up Fuel Tank Vacuum
    P148F(00) [0x148F00]
    Status: Test not completed since last DTC clear, Test not completed during this operation cycle
    P0171(00) [0x017100]
    System too lean, bank 1
    Bank 1 System Too Lean
    P0172(00) [0x017200]
    System too rich, bank 1
    Bank 1 System Too Rich
    P0069(00) [0x006900]
    Manifold absolute pressure (MAP) sensor/barometric pressure (BARO) sensor - correlation
    Manifold Absolute Pressure Sensor / Barometric Air Pressure Sensor Correlation
    P1605(00) [0x160500]
    Keep Alive Memory Test Failure
    Knock Control CPU Malfunction
    P2109(00) [0x210900]
    Throttle position (TP)or Accelerator pedal position (APP) sensor A - minimum stop performance
    P0505(00) [0x050500]
    Idle speed control (ISC) system - malfunction
    Idle Speed Control System Malfunction
    P0300(85) [0x030085]
    Random/multiple cylinder(s) - misfire detected
    Random/Multiple Misfire Detected
    P0300(27) [0x030027]
    P0300(00) [0x030000]
    P0301(00) [0x030100]
    Cylinder 1 - misfire detected
    Cylinder 1 Misfire Detected
    P0302(00) [0x030200]
    Cylinder 2 - misfire detected
    Cylinder 2 Misfire Detected
    P0303(00) [0x030300]
    Cylinder 3 - misfire detected
    Cylinder 3 Misfire Detected
    P0304(00) [0x030400]
    Cylinder 4 - misfire detected
    Cylinder 4 Misfire Detected
    P0141(18) [0x014118]
    Heated oxygen sensor (HO2S) 2, bank 1, heater control - circuit malfunction
    Oxygen Sensor Bank 1 Sensor 2 Heater Malfunction
    P0450(2A) [0x04502A]
    Evaporative emission (EVAP) pressure sensor - circuit malfunction
    Evaporative Control Pressure Sensor Circuit Malfunction
    P106A(62) [0x106A62]
    P2610(29) [0x261029]
    P0657(9E) [0x06579E]
    Actuator supply voltage - open circuit
    Actuator Supply Voltage Circuit Open
    P0100(16) [0x010016]
    Mass air flow (MAF) sensor/volume air flow (VAF) sensor - circuit malfunction
    Mass or Volume Air Flow Meter Circuit Malfunction
    P0100(17) [0x010017]
    P0010(13) [0x001013]
    Camshaft position (CMP) actuator, intake/left/front, bank 1 - circuit malfunction
    Camshaft Position Actuator Intake/Left/Front, Bank 1 Circuit Malfunction
    ABS control unit #2ABS control unit #2
    DTCs: 2
    C1404 [0x5404]
    Status: Confirmed
    C1416 [0x5416]
    Status: Confirmed
    SRS/Airbag #1
    No DTC found.
    Motor generatorMotor generator
    DTCs: 15
    P1CB7(A2) [0x1CB7A2]
    P0C3D(1C) [0x0C3D1C]
    DC to DC converter temperature sensor B - circuit malfunction
    P0E58(1C) [0x0E581C]
    P0C38(1C) [0x0C381C]
    DC to DC converter temperature sensor A - circuit malfunction
    P0E00(1F) [0x0E001F]
    P0E04(1F) [0x0E041F]
    P0E08(1F) [0x0E081F]
    P0A00(1C) [0x0A001C]
    Voltage converter coolant temperature sensor - circuit malfunction
    P0E51(1F) [0x0E511F]
    P1559(1C) [0x15591C]
    P0AED(1C) [0x0AED1C]
    Drive motor inverter temperature sensor A - circuit malfunction
    P0BE5(1F) [0x0BE51F]
    Drive motor A, phase U current sensor - circuit malfunction
    P0BE9(1F) [0x0BE91F]
    Drive motor A, phase V current sensor - circuit malfunction
    P0BED(1F) [0x0BED1F]
    Drive motor A, phase W current sensor - circuit malfunction
    P062F(44) [0x062F44]
    Engine control module (ECM), EEPROM error
    Plug-in ControlPlug-in Control
    DTCs: 47
    P0E5E(87) [0x0E5E87]
    P0E5E(49) [0x0E5E49]
    P1C1F(49) [0x1C1F49]
    P1CED(1C) [0x1CED1C]
    P1CF3(1C) [0x1CF31C]
    P1CF0(1C) [0x1CF01C]
    P0D5C(00) [0x0D5C00]
    P1C1B(00) [0x1C1B00]
    P1C1C(00) [0x1C1C00]
    P1CA4(00) [0x1CA400]
    P1C1D(00) [0x1C1D00]
    P1C1E(00) [0x1C1E00]
    P1C15(16) [0x1C1516]
    P1C15(17) [0x1C1517]
    P0D3D(16) [0x0D3D16]
    P0D3D(17) [0x0D3D17]
    P1CF6(62) [0x1CF662]
    P0D38(14) [0x0D3814]
    P0D38(12) [0x0D3812]
    P0D38(28) [0x0D3828]
    P0D2A(19) [0x0D2A19]
    P0D38(9E) [0x0D389E]
    P1C05(14) [0x1C0514]
    P1C05(12) [0x1C0512]
    P1C25(62) [0x1C2562]
    P1C00(14) [0x1C0014]
    P1C00(12) [0x1C0012]
    P1C27(17) [0x1C2717]
    P1C00(9E) [0x1C009E]
    P1C00(16) [0x1C0016]
    P1C0A(14) [0x1C0A14]
    P1C0A(12) [0x1C0A12]
    P0D4C(14) [0x0D4C14]
    P0D4C(12) [0x0D4C12]
    P1C26(17) [0x1C2617]
    P1C10(14) [0x1C1014]
    P1C10(12) [0x1C1012]
    P1C28(19) [0x1C2819]
    P1C10(9E) [0x1C109E]
    P1C10(28) [0x1C1028]
    P1CE9(96) [0x1CE996]
    P1CE9(31) [0x1CE931]
    P1CCD(9F) [0x1CCD9F]
    P1CCD(9E) [0x1CCD9E]
    P1CCE(1C) [0x1CCE1C]
    P1CCD(96) [0x1CCD96]
    HV BatteryHV Battery
    DTCs: 24
    P1C85(49) [0x1C8549]
    P3000(00) [0x300000]
    High Voltage Battery Fault; HV Battery Malfunction
    P0C30(00) [0x0C3000]
    Hybrid battery pack - state of charge high
    P31B4(00) [0x31B400]
    P0A81(96) [0x0A8196]
    Hybrid battery pack cooling fan 1 - control circuit open
    P0A81(11) [0x0A8111]
    P0A81(15) [0x0A8115]
    P0A96(96) [0x0A9696]
    Hybrid battery pack cooling fan 2 - control circuit open
    P0A96(11) [0x0A9611]
    P0A96(15) [0x0A9615]
    P0D0A(11) [0x0D0A11]
    P0D0A(15) [0x0D0A15]
    P0E6D(11) [0x0E6D11]
    P0E6D(15) [0x0E6D15]
    P0D11(11) [0x0D1111]
    P0D11(15) [0x0D1115]
    P33E6(00) [0x33E600]
    P33E7(00) [0x33E700]
    P33E8(00) [0x33E800]
    P33E9(00) [0x33E900]
    P33EA(00) [0x33EA00]
    P1B4B(72) [0x1B4B72]
    U1150(87) [0xD15087] Archive (inactive)
    Status: Pending
    U0100(87) [0xC10087] Archive (inactive)
    Data bus, engine control module (ECM) A - no communication
    Status: Pending
    Adaptive cruise control
    No DTC found.
    Radar cruise control/Pre-collision safety
    No DTC found.
    Steering (EMPS/EHPS/PPS)
    No DTC found.
    Steering angle
    No DTC found.
    Dashboard/Instrument cluster #1
    No DTC found.
    Climate/Heater
    No DTC found.
    Multimedia/Navigation
    No DTC found.
    Electric propulsion controlElectric propulsion control
    DTCs: 32
    P0571(13) [0x057113]
    Cruise control/brake switch A - circuit malfunction
    Cruise Control/Brake Switch A Circuit Malfunction
    P1578(00) [0x157800]
    ETC Power Less Than Demand
    U0104(87) [0xC10487]
    Data bus, cruise control module - no communication
    U0122(87) [0xC12287]
    Data bus, vehicle dynamics control module - no communication
    P1630(81) [0x163081]
    Internal Vref Malfunction
    Traction Control System Malfunction
    U0293(87) [0xC29387]
    Lost communication with hybrid powertrain control module
    P1631(81) [0x163181]
    Theft Deterrent Start Enable Signal Not Correct/ Main Relay Malfunction (Power Hold)
    P0D5E(00) [0x0D5E00]
    P1CDA(00) [0x1CDA00]
    P0E61(9E) [0x0E619E]
    P1CD8(00) [0x1CD800]
    P308F(49) [0x308F49]
    P309F(49) [0x309F49]
    P321D(17) [0x321D17]
    P320F(00) [0x320F00]
    P0D07(00) [0x0D0700]
    P0E6A(73) [0x0E6A73]
    P0D0E(73) [0x0D0E73]
    P0D07(73) [0x0D0773]
    P0C76(00) [0x0C7600]
    Hybrid battery system - discharge time too long
    P0A36(1C) [0x0A361C]
    Generator temperature sensor - circuit malfunction
    P1C29(79) [0x1C2979]
    P2530(12) [0x253012]
    Ignition switch, ON position - circuit malfunction
    P1C6C(9F) [0x1C6C9F]
    P1C6A(9F) [0x1C6A9F]
    P2600(96) [0x260096]
    Engine coolant pump motor - open circuit
    P0A2A(1C) [0x0A2A1C]
    Drive motor A temperature sensor - circuit open
    P0AA0(00) [0x0AA000]
    Hybrid battery positive contactor - circuit malfunction
    P0AA3(73) [0x0AA373]
    P0AA0(73) [0x0AA073]
    P274A(1C) [0x274A1C]
    P0D4C(1C) [0x0D4C1C]
    LKA/LDA
    No DTC found.
    Front radar sensor
    No DTC found.
    TPMSTPMS
    DTCs: 4
    C2121 [0x6121]
    Tire pressure sensor ID1 not received
    Status: Confirmed
    C2122 [0x6122]
    Tire pressure sensor ID2 not received
    Status: Confirmed
    C2123 [0x6123]
    Tire pressure sensor ID3 not received
    Status: Confirmed
    C2124 [0x6124]
    Tire pressure sensor ID4 not received
    Status: Confirmed
    BCM #1/Convenience systems
    No DTC found.
    Occupant detection
    No DTC found.
    Central gateway
    No DTC found.
    Single-lens camera sensor
    No DTC found.
    Adaptive Front light System (AFS)
    No DTC found.
    LKA/LDA #2
    No DTC found.
    Electric window/Driver door
    No DTC found.
    Electric window/Passenger door
    No DTC found.
    Electric window/Rear right door
    No DTC found.
    Electric window/Rear left door
    No DTC found.
    Rain sensorRain sensor
    DTCs: 1
    P000C [0x000C]
    Intake camshaft position A, bank 2 - slow response
    Status: Confirmed
    Entry & start / Smart key
    No DTC found.
    Power source control
    No DTC found.
    Grill shutters
    No DTC found.
    Electric windows main switch/control
    No DTC found.
    Special vehicle assist
    No DTC found.
  2. BiomedO1
    BiomedO1 Senior Member
    2,580
    1,388
    SacTown, Ca
    DTC's don't mean anything if your very low 12V battery is starving-out all your ECUs and sensors. You'll just be chasing ghosts. The first paragraph in the diagnostic manual states: Check 12V battery condition!!
    1. Go to harbor freight or walmart and get a cheap DVM (digital volt meter). Buy a cheap jump pack while your at it.
    2. Pull your battery and get it recharged and tested - if it's bad replace it.
    3. Don't leave your car plugged-in after it's finished charging; you can unplug it when it's convenient for you - just don't leave it plugged - in for days or weeks at a time. That's a sure way of killing your battery.
    4. Check for parasitic battery drain - You take your car to the dealership for their $400 diagnostic fee. Their just going to change the battery and bill you for it. If you come back later on; they'll hit you with another $400 diagnostic fee - but they may actually do a parasitic battery drain test this time. Win-Win for the dealership; unfortunately your pockets will be a lot lighter - who needs money anyways....
    Just my 2-cents.....
  3. FlyMode
    GTA
    2018 Prius Prime
    The battery is almost brand new! My voltage meter is showing normal readings but I definitely leave the car plugged in much longer than I need to. Sometimes for the weekend if I'm not driving so maybe that's the issue. It is on a timer though 1900-0700 daily
  4. kiwiscoot
    kiwiscoot Member
    60
    30
    Christchurch New Zealand
    2019 Prius Prime
    Don't bargain on your new 12V battery as it could be well stuffed after 12 months. A number of low discharges (as your symptoms seem to suggest) and it's toast.
    What is your normal readings?
    I would suggest put an intelligent battery charger on it overnight and then drive it for a few days and repeat the cycle (charge n drive) for a number of weeks or so. My guess you will find the Christmas effect doesn't occur.
  5. BiomedO1
    2,580
    1,388
    SacTown, Ca
    what do you consider normal readings? did you put a load resistor or battery test box on it? I've seen many batteries that have good voltage, but as soon as you place a load across it - Christmas tree effect. That's a bad battery. All those YouTube videos on how to rehab your car battery - same thing! You'll get voltage, but hardly any cranking amps.
    Details matter....
    Take the battery back to wherever you bought it. Have them test it.
    #5 BiomedO1, Nov 18, 2024
  6. FlyMode
    GTA
    2018 Prius Prime
    The battery was at 12.5v just after driving earlier today when I last checked it which I think is probably a bit low? I feel like it should have been more like 12.8 , I trickle charged it for 4-5 hours and resting at 13.4 now. I'll check again in the morning.
    Definitely going to invest in a smart trickle charger and use it every week or so like suggested
  7. Mr.Vanvandenburg
    1,311
    534
    2020 Prius Prime
    I bought yet another trickle charger. The power of sale price. Schumacher 3 in 1, 2 amp from Amazon, less than $20 with coupon. SPR1627
    #7 Mr.Vanvandenburg, Nov 19, 2024
  8. BiomedO1
    2,580
    1,388
    SacTown, Ca
    I haven't had to resort to a trickle charger, yet. Did my annual battery maintenance, last month and found it at 11.9V. A couple of hours @6A on the charger brought it back up. Still on original OEM battery. I'm going to have to start unplugging the car, since I retired a few months back. I believe this is only the 3 time I had to put a charger on the battery. I do quarterly or biannual 12V battery checks and never had a battery issue or no start condition. When I was working, I usually burn down the traction battery daily and the car was plugged-in whenever it was on my drive way. I'm going to have to adjust my behavior now.:(:oops::sleep::unsure:
    Hope this helps....
    #8 BiomedO1, Nov 19, 2024
  9. kiwiscoot
    kiwiscoot Member
    60
    30
    2019 Prius Prime
  10. kiwiscoot
    kiwiscoot Member
    60
    30
    2019 Prius Prime
    Over the weekend I found my car charges the 12V battery at 14.5V when the car is On and in Park. I charged the traction battery 100% this weekend and left the car On and in Park for a couple of hours and monitored it. It stayed on 14.5V the whole time the car was in Park. I will start to do this every couple of weeks to give the 12V battery a bit of a boost. Much easier than connecting battery chargers, etc.
  11. Mendel Leisk
    40,241
    I’d stick to external charging with an appropriate smart charger. The engine is periodically running while you do this, or the cars in EV mode? Either way, doesn’t seem efficient, nor is it likely to be as effective.
  12. kiwiscoot
    kiwiscoot Member
    60
    30
    2019 Prius Prime
    It's in City EV mode, so no engine. I park outside so much easier to just leave car on to charge itself than running cords and chargers out in the rain or weather. I am on an electricity plan where I get 3 hours of free power, so I charge the car then at no cost to me. I would think that the cars charger will be intelligent enough to charge the battery optimally when it does not need to prioritize driving range.
    I did this last Saturday for 3 hours and whereas before the battery used to sit at 12.4V, the battery now sits at 12.65V this morning. Just so much easier to leave the car on in City EV mode when I hop into the supermarket to get something quick or any other opportunity to leave it in Park and on.
    Might be interesting to leave the car on for a whole night and log it to get an idea of how it charges. The bluetooth battery monitor (BK300) makes it very easy to do that. A great piece of kit for an unbelievable cheap price.
    I will still run an intelligent multistage charger on it every month or so if needed.
  13. BiomedO1
    2,580
    1,388
    SacTown, Ca
    FYI; if someone pops your door open, they can just drive-off. Faster to just smash one of your side glass. Once the car is in ready mode, it doesn't need the fob. It's a safety feature to prevent shut-down on the interstate if your fob battery dies in-route.
    So if your not parked in a secured location - that's a gamble I wouldn't take. I'd spend the $100 on a jump pack, than leave $30K+ unsecured like that.
    Just saying....
  14. kiwiscoot
    kiwiscoot Member
    60
    30
    2019 Prius Prime
    LOL thanks for your concern but I live on the south island of New Zealand and it's safe here where I live. Many homes here not locked and many cars unlocked at supermarkets. I do fold the mirrors in at the supermarket so it just looks like I only 20231021_130449.jpg left my lights on. People like myself even camp safely anywhere here. I do think I am fortunate to live in such a safe place.
