Replaced 2 Transaxles and the HV Battery and Still Not Working... advice please.
Discussion in 'Gen 2 Prius Main Forum' started by phideltgt, Jan 9, 2012.
  1. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Sounds like incompetent dealers. Call Toyota itself, not the individual franchise and you will be able to get a charge. It is extremely unlikely one dealer has one sitting around to use on cars on the lot. Toyota does not allow that.
    Show them this if they are that clueless:
    2 people like this.
  2. phideltgt
    phideltgt Junior Member
    49
    Atlanta, GA
    It worked fine prior to pulling out the bad transmission. So, I don't think that's the culprit. I didn't touch the clutch/pressue plate during the swap.
  3. phideltgt
    49
    Atlanta, GA
    I found 800-331-4331 by googling 'phone number for Toyota'. The gentlemen said that he can't find that they have a process for charging hybrid batteries. He said they replace them.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Call and try again. The answer is they do charge them. The problem is it is so rare, the actual procedure is lost.
    Tell them to look at the Toyota Technical Training Manual, Section 5 "HV Battery Control Systems", 6 pages in on the subsection labeled "High Voltage Battery Charger"
    From the manual:
    2 people like this.
  5. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If need be, read it to the dealer or number you call. It should make enough sense to where they will transfer you to the regional rep if they can. Usually they don't do that, and then they act as a 3rd party between you so that the regional rep never deals directly with you. But you never know. Someone at that dealership should learn how to contact the correct people!
  6. phideltgt
    49
    Atlanta, GA
    Crankshaft turns beautifully, just as it should.
  7. phideltgt
    49
    Atlanta, GA
    I isolated the whining noise to the water pump assembly. Part number - 16290-21010. $95 on ebay. I could hear it and feel the vibrations in this part. I suppose after the transaxle swap I didn't put in enough coolant or it hasn't circulated or the part has gone bad. But, a relief its something small and we can rule than out.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    That bad boy was screaming! Thats good news so far. Engine turns freely.
    Back to the battery charge issue then.
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    Okay, the crank turns freely, but MG1 will only kick it slightly when attempting to start. To me, this indicates a problem inside the trans, i.e. the damper like Brit says, or a winding short in MG1. If only the HV battery were low, it is more likely that the crank would turn, but slower than necessary to trigger ignition. This is where having at least a ScanGauge would help, because it would be possible to see the HV voltage and associated drop when trying to start. I think MG1 RPM is also available? Anyway, another test would be to watch 12V bus voltage as the Ready like comes on, seeing 12V+/- jump to 14V+/- when the DC converter comes online.
  10. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Just a thought if the car can be made ready and put into D if you tow the car surely regen from MG2 will charge the HV battery or am I missing something.
  11. phideltgt
    49
    Atlanta, GA
    Great idea. I am definitely thinking about doing this. Can I possibly tear something up, though? What thoughts to other have about this?
  12. Britprius
    5,194
    1,921
    Providing it can be put into D no harm at all, if you have an EV switch but I believe unlike the UK in the US you do not, you could stop the ice from trying to run till the HV battery was fully charged.
    You will know as soon as you get above 7MPH if the battery is charging by the green arrows on the MFD. If you gently apply the brakes (dependant on what your towing with) this will increase the charge rate and reduce the distance you need to travel. Best of luck.
    Jhhn.
  13. Britprius
    5,194
    1,921
    If you do tow the vehicle make sure the 12v is well charged or even put another battery in parallel with it as it runs the brakes and the power steering.
    John
  14. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    How many bars are on your battery display? It will start with 1 bar, even none, but if it is none, you don't know how much charge you have. Get a digital volt meter, remove the cover from the left side of the battery pack. You will see two relays with thick red wires. You want to measure the voltage between the 2 wires on the right (passenger side in US) of each relay with the car off. Make sure you only touch the plastic on the meter test points, 200 volts can present a nice shock. To be extra careful, remove metal jewelery, watches, rings etc. from you hands incase you slip.
    Also, are you getting and DTCs?
  15. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Pat mentioned this before, I think that HV is only present when the relay(s) make. At that point the normally isolated ground is now present. Sound right. If the OP gets into that area, it would be nice to have a photo and the measurement points.
  16. seilerts
    3,326
    1,517
    38
    Santa Fe, NM
    A scangauge, mangoose, etc is a much easier way to get the voltage.
    It is somewhat of a chore to get to the terminals. The procedure is: Open the hatch. Take out the carpet, the floorboard, and the black storage tray. Remove the little storage compartment and its cover from the driver's side. Pop out the plastic deck trim panel that covers the hatch latch. Loosen the large driver's side trim panel, a combination of body clips and 10 mm screws. Move to the back seat, and remove the driver's side back seatback, and pull forward (but do not remove) the top of the trim that runs between the seatback and the door frame (i.e. on the other side, this is the piece that has the HV battery fan inlet). The HV battery has a floorboard covering -- use a trim tool and pop up the clip in the forward center, then it will slide of the other two clips that are on the rearward sides. Now it is possible to remove the large side panel, which then exposes the battery bracket bolts. Remove that, then remove the terminal cover bolts.
    The Prius Dismantling Guide is very helpful for the job. Use Google.
    The picture below shows the terminals. Normally, you will find two white caps covering the terminals on the battery side of the system main relays (the two black things with copper strips). I cannot emphasize enough the risk to your person if you get this far, and you have left the 12V battery and service plug connected. In fact, I suggest: disconnect the 12V and service plug, get the terminals exposed, clipping leads to the the frame wires, install the service plug (handle must slide all the way down), turn on your meter (should read 0V) connect the 12V, and make the car Ready. Watch the voltage as soon as the SMRs click on. Any reading above 200V at any time suggests to me that the battery is not the problem. From my experience with bad packs, the car will still start even if voltage sags as low as 6V per module, 168V.
    3 people like this.
  17. andyprius
    2,212
    188
    HELLO Seilerts, Excuse my nitpicking, but at what points are ones pos and neg leads of meter on? I understood that the two orange leads are not measurable as both are positive and a main relay R1 or R3 makes a usable normally isolated ground. As you see I also have a 05. I am just gathering information, I do not plan on tearing into the battery case. :D Thanks for the great photo.
  18. edthefox5
    10,096
    4,832
    Clearwater, Florida
    Doesn't matter. Your just looking for the volt level it doesn't matter if its reversed. It will read the same volt level. Either -200 or 200. Just need the 200.
    But if you need to know you'll find out real quick when you hook the probes up.
  19. phideltgt
    49
    Atlanta, GA
    I have a volt meter similar to the one pictured below with leads. I suppose I will need to pick up some clamps, so I don't have to stand and hold the leads? or get a voltmeter with clamps. I was also going to pick-up some electrical gloves from home depot. I wanted to confirm where to clamp them the leads, though. I've marked up the picture below. Please confirm this is what was meant? Thanks for your patience.
    meter
    battery
  20. phideltgt
    49
    Atlanta, GA
    Sometimes I have zero bars on the battery, sometimes one bar. I'm quite sure I have many trouble codes. I have a universal reader, so I'm not sure that will help us.
