Replaced boot battery dash dim help please
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by iron-icman, Dec 16, 2017.
  1. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Hi guys,
    Went to my car the other morning to which nothing worked and then thought it may be battery so replaced this and had no problems since strange how it just went.
    Car is still working fine however the main square dash centre seems to get a bit dimmer after a little bit when I press the dimmer it does go bright again but when I dim it to the night setting it then dims more after a while.
    Any idea or tests I can do.
    Not very technical minded with electrics and testing so be nice.
    All in all loving the car
    WilDavis likes this.
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Measure/test/check 12V AuxBattery, since it sounds like something is starting to get flakey. Rather than repeat all the steps, allow me to point you to "search" and mention there are many (dozens I daresay) of threads explaining and suggestions of solutions to your problem! - hope this helps - Wil ;)
    …oh, and by the way, I've found that the dimmer switch (in my 2009 Gen II) is quite sensitive, and can be easily nudged to a different position , or even switched "off" (read my post re. "Oh no, not the Combination-Meter-Problem yet again!) :eek: :rolleyes: ;)
    iron-icman and Andyprius1 like this.
  3. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Thank you will check it out
    51,155
    and check the battery connections, especially the neg to body.
