Replaced Brake Pedal Switch - Increased MPG?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mr_tim, Mar 27, 2019.
  1. mr_tim
    mr_tim New Member
    Hertfordshire, UK
    I was getting the Exclamation/ABS/VSC warning light combo about 6 months ago and had my skid control unit replaced which fixed the issue. Strangely my MPG seemed to take a nosedive from 49/50 on my daily commute to <42.
    Earlier this month the lights were back. Having had the skid control unit replaced I decided to try replacing the brake pedal switch myself. After dismantling the dash and getting to the switch it turned out the new switch I had only had 2 connections rather than 4. Regardless I gave it a go. A few days in and no errors later my MPG has jumped to 50+. Any ideas why this could be?
    Cruise control doesn't work - I guess the missing connectors were maybe used by that?
    Prior to replacing the switch, Techstream was reporting the same error across ABS/VSC and Cruise Control units
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    What DTCs did techstream report, before and after?
  3. mr_tim
    mr_tim New Member
    Hertfordshire, UK
    Before replacing the pedal switch I had:
    P0571 and P0607 on the Hybrid and Cruise controls.
    C1249 (open circuit in stop light switch circuit) on the ABS/VSC/TRC
    Now I just have a P0571 (brake switch A circuit) on the Hybrid and Cruise Control.
    If I try and turn cruise on, the word flashes a couple of times and disappears
    Any thoughts?
  4. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Did someone sell you the wrong switch? I wonder what would happen if you used the correct switch?
