Replaced combination meter and still not working
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Annalisa, Dec 24, 2021.
  1. Annalisa
    Annalisa New Member
    Wisconsin
    Hi y'all, I have a 2005 prius with roughly 175,000 miles on it. About 4 months ago, we started having issues after longer drives (hour or longer). After turning the car off and sitting over night, the dash lights wouldn't come on and no power steering. However the engine ran fine and after about 20 minutes of driving all systems would turn back on. All dash lights, power steering, heater and such. Then after driving a bit longer or turning car off and on, eventually no warning lights. Car had zero issues for weeks when running short errands around town, just longer use issues. Took it to the dealer, paid $950 to have combination meter replaced, Took a 6 hour trip and same problem today. It seems that it occurs after engine has been off and cooled significantly and the problem to make it go away is to warm up the vehicle. Any suggestions? Thanks!
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    Did you pay the dealer for a diagnostic, if so which OBD2 code (DTCs) did they find to support a combination meter replacement?
    FYI : you're moderated until you've posted 5 times.
  3. Annalisa
    Annalisa New Member
    Wisconsin
    Thanks, it was an authorized Toyota dealer, they didn't say the code, only said it was the combination meter. I plan on calling on Monday when they reopen, but was hoping to get other guesses from others who may have had the same or similar situations.
  4. PriusCamper
    PriusCamper Senior Member
    11,092
    4,514
    Pacific Northwest, USA
    I have zero confidence in the delearship's ability to deal with this one. They're gonna charge you a fortune replacing stuff with brand new... This is something anyone with intermediate soldering skills can fix... Or do it with Texas Hybrids: Prius Speedometer Replacement
  5. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Maybe this?
    2004-2009 Toyota Prius Combination Meter Warranty Extension ZTV | TOYO Headquarters
    Background
    "Toyota has received a limited number of reports from high mileage 2004 to certain 2009 model year Prius vehicles regarding the Instrument Panel Combination Meter not illuminating when the vehicle's ignition is turned "ON". This condition may occur in certain cold weather conditions and is identified during vehicle start-up."
  6. bisco
    49,433
    was the meter having any issues before or after they replaced it?
  7. mr_guy_mann
    mr_guy_mann Senior Member
    3,456
    1,502
    NJ-USA
    If the engine runs and you can drive the car but several systems don't turn on then I would be looking at at a wiring diagram for powers and grounds to the affected systems. Or using a capable scantool to see if anything is "offline" when you have problems.
    I don't think the "classic" combination meter failure really fits your symptoms.
  8. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you and your Prius are up for a car trip, Steve at autobeyours.com in southern Indiana is a knowledgeable and reliable Prius Mechanic.
    JeffD
    Annalisa likes this.
  9. Annalisa
    Annalisa New Member
    Wisconsin
    It had issues before, they said it was in fact the combination meter that was the problem, they replaced it and still having the same problem as before.
  10. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Was under the impression that they had opened a second location in northern Florida, so that car trip may not be that far after all.
  11. bisco
    49,433
    from 'sconsin?
    SFO likes this.
  12. bisco
    49,433
    i think eric becky is in madison
    Raytheeagle and SFO like this.
  13. bisco
    49,433
    has the 12 volt battery been tested yet?
  14. bisco
    49,433
    it sounds like something is overheating on the long drives. are the fluid levels ok?
  15. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Yeah, saw Another and FL.. guess not, lol.
    Annalisa and bisco like this.
  16. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    Have you checked that your inverter coolant water pump is pumping fluid properly?
    This Luscious Garage video 'Gen 2 Prius Inverter Water Pump Flow' shows you how you can quickly check to see if your inverter coolant water pump (ICWP) is working well.
    This post by Patrick Wong will give you an idea of what is involved to change the ICWP if you find is no longer working. You (and/or a friend) can likely do this. If you do do the job yourself, use a genuine OEM (i. e. Toyota) part for long-lasting results.
    As mentioned in another post above, if you're not able to do the job yourself, Eric Becky is in Madison, Wisconsin, and will certainly be able to help you out. He is always happy to take your call and work through the problem with you.
    EV Powers Hybrid Battery Service and Repair
    Your Hybrid Battery Hero
    Madison, WI
    [email protected]
    608-729-4082
    Facebook: EV Powers Hybrid Battery Service and Repair
    #16 dolj, Dec 27, 2021
    Annalisa and SFO like this.
  17. Annalisa
    Annalisa New Member
    Wisconsin
    Yes, it was brand new in September. That was the first course of action when the problems started
  18. bisco
    49,433
    give eric becky a call in madison
