Replaced complete EGR system w/photos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dame3780, Jan 5, 2019.
  1. dame3780
    dame3780 Member
    59
    52
    SoCal
    My turn! I'm at 148k miles. I was due for this. Plus after seeing everyone's filthy EGR, I knew mine would be the same. I purchased an all new Toyota EGR pipe, valve, and cooler. I followed the repair manual and also watched those @NutzAboutBolts videos. All very helpful, thank you! My car has been running fine but I have been noticing more vibrations coming from the engine and especially noticeable when the ICE kicks on/off. Now, it is super smooth and it feels like it did when it was new. So...score! While I had everything apart, I tackled a few more things: cleaned the intake manifold, throttle body, replaced the PCV valve, engine coolant again, and also the engine water pump. Everything back together and all was good! Here are some photos:
    pjksr02, Simtronic, Zaza 13 and 12 others like this.
  2. JC91006
    16,482
    8,400
    Good job! Now you have some spare EGR parts
    RMB, dame3780, m.wynn and 3 others like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Good job and we’ll done (y).
    More data:).
    Some questions:
    • How much resistance did you find in the impeller for the water pump?
    • Did you see how it compared to the new water pump?
    • You bought a new cooler and egr valve from Toyota?
    I have @The Critic ‘s cooler that I’ll post some pics of and clean with a pressure washer.
    I am interested in what you find with regards to the engine water pump resistance of the impeller. Since the pumps are magnetically driven, you have no overt signs of failure like you do with a traditional water pump.
    Good work and thank you for sharing ;).
    We need more to do so to have the data available(y).
    RMB, SFO, dame3780 and 2 others like this.
  4. mjoo
    mjoo Senior Member
    1,126
    1,316
    Michigan
    Looks like Christmas!
    It sounds like you were able to clean all 4 EGR ports in the intake manifold.
    Pixel XL ?
    #4 mjoo, Jan 6, 2019
    RMB, m.wynn and Raytheeagle like this.
  5. qettyz
    qettyz Active Member
    181
    206
    Finland
    Very big thumbs up!
    This is excatly what ive been thinking to do if and when my car hits around 200k km.
    But, might take years since now im at 40k km and i drive ~25k km per year;)
    dame3780, m.wynn and Raytheeagle like this.
  6. ASRDogman
    ASRDogman Senior Member
    6,091
    3,273
    I'm very happy for you!
    Why did you decide to buy a new cooler versus cleaning the original one? Are you going to clean it and
    reinstall it next time?
    RMB, dame3780, m.wynn and 2 others like this.
  7. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    Excellent work!(y)(y)(y)
    Does the car burn any oil?
    How gooked up were the intake manifold EGR ports?
    RMB, dame3780, Mendel Leisk and 3 others like this.
  8. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    How much did the pump cost
  9. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    I guess I should have also asked if you did the engine thermostat as well since it is just opposite the water pump.
    If not, I’d plan on doing it on the next round of coolant exchange.
    dame3780 and m.wynn like this.
  10. m.wynn
    684
    1,226
    Queensbury, NY
    Just for reference, 2 years ago now (Jan, 25, 2017), I bought the Aisin packaged pump (WPT-190) with the Toyota stamp ground off for $280.19 shipped via eBay. They appear to be trending for even a bit less, currently.
    #10 m.wynn, Jan 6, 2019
    RMB, JC91006 and Raytheeagle like this.
  11. Mendel Leisk
    38,726
    That bit I think:
  12. m.wynn
    684
    1,226
    Queensbury, NY
    Raytheeagle and Mendel Leisk like this.
  13. Mendel Leisk
    38,726
    I search the part number on ebay and see with and without the Toyota logo, around $200~250.
    Engine water pump:
    Toyota p/n: 161A0-29015
    gasket p/n: 16291-37020
    Inverter water pump:
    Toyota p/n: G9040-47090
    tankyuong, RMB, dame3780 and 2 others like this.
  14. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    You mean this:
    7948D6CA-35F3-4997-85A0-7069B23A83B5.jpeg 15992A4F-677D-403D-8A13-5C2B6B36BF86.jpeg
    That’s one of the next pumps on the list and this will also be done soon:
    E68F58B7-32E2-4720-AA9B-9B3897B0131F.jpeg 75497554-33EE-4F8C-A847-F1D8B316FB1B.jpeg
    After these preventative maintenance items, I should be ready for the @bisco challenge (y).
    tankyuong, RMB, bisco and 2 others like this.
  15. m.wynn
    684
    1,226
    Queensbury, NY
    Welcome to Over-Maintainers-R-Us, where the first step in fixing your problem is admitting you have a problem.:cool::D:D
    Absalom, RMB, JC91006 and 5 others like this.
  16. farmecologist
    farmecologist Senior Member
    1,948
    1,786
    Southern MN
    Nice work!
    Say do you mind posting the part numbers of the parts you ordered? Those might come in handy at some point.
    I have a 143K Prius v (wagon) that is due for EGR service this spring. I bet my EGR cooler will look exactly the same as yours by that time! (y)
    RMB, Raytheeagle and m.wynn like this.
  17. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    The egr cooler is the same as in your Prius ;).
    I thought you had an extra lying around:whistle:?
    If not, a pressure washer will make quick work of thebtask with the original parts(y).
    RMB and farmecologist like this.
  18. farmecologist
    1,948
    1,786
    Southern MN
    Yep I do....the spare EGR is all nice and shiny due to the oxi clean soaks. (y)
    However, it looks like they ordered a bunch of other new parts as well. Just thought if the part #'s were handy it might be good to throw them up here.
    Raytheeagle likes this.
  19. dame3780
    dame3780 Member
    59
    52
    SoCal
    @Raytheeagle Water pump was in good shape by the looks of it. Resistance was not as good as new. If spinning the new, it would stop say in 1 second. If spinning the original pump, it would stop in 2.5 seconds-just as a comparison in non-tech words lol. I was running out of daylight under the carport so had to wait on the thermostat/water inlet tube. Next on the list is the inverter pump/coolant.
    @mjoo All 4 intake ports were cleaned out with parts wash/brake cleaner and wiped clean. Installed new gaskets. I think I have a pic. There was oil sitting under the throttle as you can see in one picture.
    @ASRDogman The biggest factor was time. Wasn't sure how long it was going to take to clean it all out. So purchased new Toyota parts from an online supplier from Japan (JP-carparts.com). I've used them numerous times for the Prius and our LS. Shipping is fast! I received a part faster than one ordered from same state. I will now have the time to clean them up and use next change out for sure.
    @m.wynn Not burning oil. Intake was not so bad. Worst was the exit to the EGR tube.
    @tankyuong Pump was $245 from Toyota dealer.
    RMB, mjoo, SFO and 2 others like this.
  20. dame3780
    dame3780 Member
    59
    52
    SoCal
    @farmecologist Here are the part numbers:
    • EGR Pipe- #25610-37012
    • Cooler-#25601-37010
    • Valve-#25620-37120
    • Gasket Pipe-#25685-37010
    • Gasket Pipe-#25634-37010
    • Gasket Valve-#25627-37010
    $433 + $59 shipping= $492
    tuner429, pjksr02, RMB and 5 others like this.
