Replaced complete EGR system w/photos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dame3780, Jan 5, 2019.
  1. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Thanks! I'm sure these will show up in PriusChat searches at some point now. It's nice to have the part number to go along with the part name when you do a search. (y)
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    It just so happens I have 2 replaced engine water pumps currently on hand:
    The top pump is the one out of our 2010 at 175 k miles and the bottom one is out of @The Critic ’s at 180 k miles. Both spin in the same manner as described above: stop after about a second and there is a bit of resistance if just simply rotating.
    Below are pics of @The Critic ’s Cooler after the same 180 k miles:
    24839E03-98B8-4EFA-9313-892D75C91B7D.jpeg 0AC05268-6CB0-4602-AB6D-1116A232DB1C.jpeg
    While not completely clogged, there are deposits;).
    More data(y).
    RMB, m.wynn and dame3780 like this.
  3. dame3780
    dame3780 Member
    61
    55
    SoCal
    The more data the better!
    The 2 ports on the outside of the intake (passenger side) were wet looking. Worn gasket I believe. I didn't notice this at my last oil change 3k miles earlier. Glad I did all of it.
    @Raytheeagle When are you going to clean out your EGR again? I was thinking at the next spark plug interval.
    RMB, m.wynn and Raytheeagle like this.
  4. Mendel Leisk
    42,347
    That will require an oil catch can to keep at bay; it's regularly refilled by the pcv hose.
    dame3780, RMB and Raytheeagle like this.
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    My plan (given our Prius consumes a bit of oil) is to pair every engine coolant change with the cooler circuit cleanse;).
    Might sound extreme to some, but this job ain’t that bad and I have everything off and ready:).
    But definitely plan on doing it again I would say and less mileage before the next one(y).
    dame3780, RMB and m.wynn like this.
  6. Mendel Leisk
    42,347
    After the first coolant change it's 50K miles (or 5 years) on the US schedule, sounds like a good schedule.
    Still, you don't have to sync coolant change with EGR clean, if the object is to avoid coolant spill: just draining a couple of liters of coolant into a clean container at the outset, the coolant level drops below the EGR. Then pour it back into the reservoir after.
    And, clamping the coolant hoses before removal is somewhat futile: the EGR cooler is above some of the hoses.
  7. padroo
    padroo Senior Member
    2,763
    2,253
    Once we go to all EV cars and the ICE is gone, what will we have to talk about? :)
  8. Mendel Leisk
    42,347
    Brakes. :):sleep:
    RMB and padroo like this.
  9. padroo
    2,763
    2,253
    I predict that they will go to all electric brakes with no friction pads sometime in the future.
  10. qettyz
    qettyz Active Member
    181
    208
    Finland
    Battery cooler pump etc :)
    m.wynn likes this.
  11. padroo
    2,763
    2,253
    The new generation of mechanics will need to be an electrician first or they won't be able to troubleshoot the car.
    How do you spell education?
  12. Mendel Leisk
    42,347
    I recall Toyota or Honda (maybe Honda) starting an assembly plant in the States, and they had to teach a lot of the new hires basic math. I believe they were all (or mostly) high school grads.
    Also recall, when I took my Vocational School steel detailing course, that was the first time trig started making sense to me. Practical applications in particular, make something click, I find.
    RMB, m.wynn and padroo like this.
  13. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    While not
    Just need the proper tools for the task;).
    Techstream comes to mind(y).
  14. padroo
    2,763
    2,253
    We are in trouble in the US as far as education goes. Back when I was in my mid 30's I joined the US Air Force Reserves.
    You had to pass a test to get in so I went to South Bend Indiana with my recruiter and took the test with a room full of people. You have to have a high school diploma even to get into the reserves so everyone in the room had at least that as far as education goes. Then the sad part, the recruiter told me that half the people in this room will fail the test.:(
  15. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    For data reference, here's a look at the dirty cooler from my 2010 at 142k miles:
    And cleaned up with the quick and dirty, 2 or 3 cans of Brakleen flush:
    Of note, the car was a zero oil burner until it's tragic passing at 150k miles. It did, however, suffer the light acceleration shudder with blockage of the intake manifold EGR small ports at 97k miles. This was easily remedied to silky smooth light acceleration with a quick and dirty IM pull and clean.
    dame3780 and RMB like this.
  16. padroo
    2,763
    2,253
    Techstream will help but there is a whole lot more to troubleshooting than just having the right tools.
    Most Toyota dealers do not even own a labscope.
    Oscilloscope | Pico Technology
    Sorry, I got way off topic.
  17. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Meh, ICE technology isn’t going anywhere any time soon. And when it does, society will adapt;).
    And tools will be better understood as the technology develops to deal with troubleshooting needs.
    As someone who works for a company that a lot of their technology is still 20th century, I’m helping push them toward the 21st:).
    If we don’t adapt, we’ll get left behind :cool:.
    And I’m making sure I stay up on technology and doing what I can do promote the same(y).
    m.wynn, padroo and RMB like this.
  18. JC91006
    16,936
    8,647
    Those are some high prices for gaskets and stuff. I still remember changing my gen 2 water pump and belt for $60
  19. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    I’ve bought the gaskets for about $30.
    A new cooler and valve are excessive where a salvage one is just as good and 1/3 the price.
    But if you can clean the cooler with a pressure washer, you wouldn’t even need the spare.
    Maybe I should look at selling my spare:whistle:.
    m.wynn and RMB like this.
  20. Mendel Leisk
    42,347
    Doing the EGR and intake manifold, I didn't change any gaskets. To be fair, this was with a measly 76K kms. Also, no new compents, just clean everything. The EGR pipe and valve are a walk in the park, the cooler just takes a little patience and some chemistry. Or @Raytheeagle's blaster.
    m.wynn, RMB and Raytheeagle like this.
