Replaced complete EGR system w/photos
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dame3780, Jan 5, 2019.
  1. 04priusnow
    04priusnow Active Member
    345
    201
    No oil burning. Change oil every 8k miles or so
  2. 04priusnow
    345
    201
    I didn't swap out the intake.. I should have maybe this spring.
  3. 04priusnow
    345
    201
    Mendel Leisk and Raytheeagle like this.
  4. Mendel Leisk
    42,365
    If you mean replace: it's easy to clean. Brushes for cleaning steel drinking straws are good for the small EGR passages.
  5. 04priusnow
    345
    201
  6. 04priusnow
    345
    201
  7. Mendel Leisk
    42,365
    Cylinder one, or in between one and two, is the common head gasket failure point, reported here and by gasket masters. When intake manifolds are pulled off for inspection/cleaning, the small EGR passages tend to be most clogged at cylinder one. The EGR gas enters the manifold at the other end, cylinder four.
