Replaced evaporator put it all back together now won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by HAWGMAN, Jul 28, 2024.
  1. HAWGMAN
    HAWGMAN Junior Member
    17
    Murray, KY
    Followed the guide on removal and I replaced the Evaporator and expansion valve. Also soldered a new capacitor to fix the instrument cluster ( I have done this repair before). Now when I reconnect the battery the alarm sounds and flashes. Once I stop the alarm the car wont start and the blinking symbol is not on in the dash. The open door symbol is the only one lighting up and the flashers. I checked the immobilizer its plugged in any other suggestions? (other than take it all out again and replug everything? Its a 2006 and I cant run the codes since it wont start btw.
    #1 HAWGMAN, Jul 28, 2024
  2. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    I presume you mean the capacitor. If you really mean you replaced a resistor, you might need to revisit.
    You don't need it to start, just get to IG-ON (two presses of the power button with your foot OFF the brake pedal).
  3. HAWGMAN
    17
    Murray, KY
    yes capacitor. my Son in law came and helped me find the plug I missed. thought it was the brake switch it was actually a long plug behind the blower assembly that went to box on the firewall. anyway all is good now.
    Brian1954 likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    That's a big job to tackle. Well done!
    HAWGMAN likes this.
