Replaced injured door, window won't work
Discussion in 'Gen 3 Prius Technical Discussion' started by Ryan Smith, Aug 19, 2023.
  1. Ryan Smith
    Ryan Smith New Member
    Oakland, CA
    Hi All,
    I replaced the driver side rear door with a used one. The auto lock works fine, but the (motor controlled) window does not roll down (either with front control or rear control buttons). Any ideas on how I can get the window to roll down? I heard someone mention that I should "reprogram" the window (perhaps with the OBD?), or that I should swap the electrical cables from my old door. I don't see how different wires would make any difference though. Thanks for any hints or ideas!
    Best regards,
    Ryan
  2. ChapmanF
    18,996
    First things first, does the window motor in that door work if you bring it 12 volts directly?
  3. Ryan Smith
    Oakland, CA
    This is a good point. I will check this.
  4. Tombukt2
    Tombukt2 Senior Member
    13,844
    2,515
    Durham NC
    Sounds like you may have a bad window motor as being mentioned possibly above by supplying 12 volts known to the system door and window motors do go bad.
