Replaced Inverter Converter, No start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TracHoeOp487, Jul 26, 2024.
  1. TracHoeOp487
    TracHoeOp487 New Member
    Oregon
    I
    I replaced Inverter/converter after 110degree day, my Inverter pump quit, replaced, the Inverter overheated, also blew a 15 amp fuse under hood lost all dash lights and power, replaced 12v battery also, since it got drawn down, when car died was in drive doing 80mph on hwy, Fast forward replaced all 4 car won't start, all codes were lost. Car when you push start lights up etc, will shift to neutral but if you try drive it won't start, any suggestions would be greatly appreciated, I've checked all fuses with multimeter, and swapped gateway, transmission ecm, reset Car ecm with paper clip method, any input appreciated, thank you
  2. ChapmanF
    18,757
    What are you using to read trouble codes?
    Brian1954 likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    All 4? Does that mean you replaced the ICWP, the inverter, the 15 amp AM2 fuse and the 12v battery?
    If so, I'll assume you popped out the HV battery safety disconnect? If so you may want to verify it's properly installed. Seems simple, but the third step of installation often gets forgotten. Push it down to activate the interlock. Without the third step, the car thinks the safety switch is still removed.
    Unfortunately, you've done so much for what is usually a very simple repair, that it may be difficult to get anyone to work on it. Hopefully this is something very simple, like the orange switch.
    #3 TMR-JWAP, Jul 26, 2024
  4. TracHoeOp487
    Oregon
    I
    Yes HV battery switch is fine and it was reconnected, I checked the fuse in that also, it's good. Only thing I can come up with at this point is the relay switch for starter? Which one is it? Even when I look in manual and map on fuse boxes I don't see anything for starter.
  5. TracHoeOp487
    Oregon
    I
    I have a maxidus 808 I think it is, when car died there weren't any codes, that's why it became pretty difficult, I've worked on it quite a bit in past, car has about 550,000 miles, it's a great car, it's in excellent condition.
  6. ChapmanF
    18,757
    We do have a thread here that compares code-reading options and suggests some good choices that will be able to show all the codes in a Prius. Without one, you're right, problem-solving becomes pretty difficult.
    Gen2 OBD2 app review | PriusChat
