Replaced Skid Control ECU, techstream won't clear old code
Discussion in 'Gen 2 Prius Technical Discussion' started by Brett Kowalczyk, Mar 28, 2021.
  1. Brett Kowalczyk
    Brett Kowalczyk New Member
    Delaware, OH
    I replaced a skid control ECU with a used one from ebay. The old ECU showed me a problem with the rear right hand wheel speed circuit. this new one is no longer showing that problem but is showing a problem with the rear left hand wheel speed circuit.
    Using textream, I cannot clear this code. When I drive and watch real time data, though, it shows that wheel has the same speed as all the others. Thoughts on what might be going on?
    Also, I've performed the yaw rate sensor calibration and also the linear solenoid initialization, but it says certain lights should blink during this process but they don't. Maybe related? Maybe not?
    PriusCamper likes this.
  2. ChapmanF
    19,052
    My first questions would be (1) what is the exact code for the rear left sensor that you are getting, and (2) what does the repair manual (more info) say is the exact detection condition for that code?
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Please post the old DTC (OBD2 code), and the current DTC in this thread for further assistance.
