replaced three way coolant valve, again, now i’m overheating
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gino Veltri, Mar 13, 2024.
  1. Gino Veltri
    Gino Veltri Member
    380
    36
    i just replaced my coolant valve for a second time because of a p1123 ect. Same procedure but this time i bled both systems and now i’m overheating. Additionally, the car has had heater problems intermittently, now it blows ice cold air (no heat). while jumping the coolant heated storage pump to bleed the air out my multimeter was only showing 1.3 amps at most with the car off and battery attached. shouldnt it be higher?
    It sounds like air in the system plus a defective heater core or something. i also think i stripped the heater core bleeder valve (the plastic one with a hex key) so that’s just another part of my screw ups. but hey, no more check engine light!‍♂️
    this is a 2008 prius with 289889 miles, the brake actuator accumulator runs way too often and the tpm warning light is always on.
  2. JC91006
    16,470
    8,390
    you should wait until the car is cool, open the radiator cap, and then fill it all the way up
  3. PriusCamper
    PriusCamper Senior Member
    11,028
    4,483
    Pacific Northwest, USA
    Yeah... Most hot running engine issues are resolved doing this multiple times / every time your engine is cold before you drive somewhere.
    However the intermitent heater issue still needs a diagnosis, unless it's as simple as replacing the stripped bleeder valve and getting the air out of the heater core once that's done.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,172
    5,859
    Columbia, SC
    or hoses got mixed up
    pasadena_commut and PriusCamper like this.
  5. dolj
    dolj Senior Member
    7,588
    3,828
    Wellington, New Zealand
    This is how the plumbing should run:
  6. Gino Veltri
    Gino Veltri Member
    380
    36
    thanks for that diagram, i burped and burped (there’s still air trapped in there) but my heater works again and we aren’t over heating anymore so all is well in prius world… i mean except for the amount of oil she eats
