Replaced Turn Signals, Fog Lights, High Beams, Parking Lights & Rear License Plate Bulbs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by stream, Jun 13, 2009.
  1. praecurvo
    praecurvo Junior Member
    34
    Boulder
    bump
  2. WE0H
    WE0H Senior Member
    3,247
    528
    Look on eBay. There are tons of LED indicator lamps for whatever vehicle you own. Try a 10k 1/4w resistor in parallel with the lamp socket and see if that brings the blink rate back to normal. If it is still to fast, drop the resistor value down a bit until it blinks at the right rate. Do the math so you use the proper wattage resistor. Solder and heatshrink all connections so they are done right and will not cause issues later. Piece of cake :p
    Mike
  3. praecurvo
    34
    Boulder
    Wow, thanks. I appreciate you taking the time to post the correct answer. If I could free up the time, I would. Alas, I choose not to. I was hoping for a one-two let's go method.
    thank you again WEOH.
    aaron
  4. WE0H
    WE0H Senior Member
    3,247
    528
    You may find some plug & play LED lamp assemblies on eBay, but the last time I was looking, there were separate resistors that were being sold so you would have to wire those in. Still easy as pie. Go for it.
    2 or 3 years from now the wife says I will have a Gen 3 Prius and I assure you it will have all LED lighting. I just have to wait until some other cars here are paid off before we can take on another payment. We have 5 cars and a SUV already...For now I drive rental Prius's when we travel :D
    Mike
  5. praecurvo
    34
    Boulder
    ty WEOH.
    aaron
  6. gblatt
    gblatt New Member
    46
    Sterling, VA
    I intend to change out some of the lights too but clearances and access to changing out the bulbs at the headlamp are pretty tight, and doing it blind too since its near impossible to see anything in there. Is it better to just loosen the screws on top of the assemble to gain access?
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    On the passenger side, you need to remove a bolt and move a hose and another piece--instructions are in the owners manual in the bulb replacement section.
    It is a tight fit, but if you take your time, it's not that bad.
  8. gblatt
    gblatt New Member
    46
    Sterling, VA
    Has anyone tried using LEDs in lieu of the Blue Vision for the parking lights? I have seen some T10 wedge LEDs that are supposed to be replacements for W5W but the stock W5W is a T3 1/5 so I'm concerned that the LED won't fit.
  9. krouebi
    krouebi 2012 Peugeot 3008 HYbrid4
    55
    Grand Duchy of Luxembourg
    Hi there,
    Yes, we have LED replacements for the parking lights on both Priuses - no problems so far, whether fit nor function-wise.
  10. gblatt
    gblatt New Member
    46
    Sterling, VA
  11. krouebi
    55
    Hello there gblatt,
    The ones you found on eBay:
    might very well fit - but I can't tell for sure. On the 3rd Gen Prius I have something like this:
    which is excellent, but also a bit more expensive (12.99 USD from 194 T10 W5W 9smd Wedge bulb : eBay Motors (item 280340222998 end time Jul-23-10 20:51:41 PDT)). They are a quite tight fit, and maybe the 5-LED version (smaller/shorter):
    - which I use on the 2nd Gen Prius - would be a better choice. It's available from here: Xenon White T10 168 194 W5W Wedge 5 SMD 5050 LED LIGHT: eBay Motors (item 280537481016 end time Jul-23-10 14:13:39 PDT) .
    The 9 LED version is VERY bright, almost too much so - but the do look quite cool :rockon: .
    2 people like this.
  12. gblatt
    gblatt New Member
    46
    Sterling, VA
    Thanks, this is most helpful
  13. Tideland Prius
    16,553
    The SMD-type bulbs (2nd and 3rd pic) will be a lot brighter than the bulb in the first pic.
  14. ryutaroh
    ryutaroh Junior Member
    Japan Nagoya
    i bought 2010 prius.
    so, iwant changed from jdm prius to usdm prius !!
    but, i dont know us prius headlight and taillight parts number.
    can u teach me head light and tail light parts number ?
  15. Tideland Prius
    16,553
    hello and welcome to PriusChat! We do have Japanese packages listed (S, G, S Touring, G Touring and G Touring with Leather) so feel free to adjust your profile!
    The only thing different on the outside would be the addition of yellow reflectors for the headlights and red side reflectors for the rear taillight. We also have the underbody spoilers and the rear underbody spoiler as standard equipment.
  16. gblatt
    gblatt New Member
    46
    Sterling, VA
    I just got the 9 LED version in the 2nd pic. The are very tight and barley fit. The top LED looks like is just touching the glass. Not dark out here yet so I am eager to see what they look like. I will post pics.
  17. gblatt
    gblatt New Member
    46
    Sterling, VA
    Wow, the 9 LED replacement is pretty bright. It looks a little whiter too than the LED headlights.
  18. WE0H
    WE0H Senior Member
    3,247
    528
    Damn cool looking :)
    Mike
  19. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Those sure do light up the housing! I only have a 5 LED version - they are BRIGHT!
  20. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    Well I ordered both twin packs for High and low beams from Amazon.com... "free shipping... total for all 4 bulbs came to 118.00
    [FONT=verdana,arial,helvetica][SIZE=-1]Subtotal of Items: [/SIZE][/FONT] [FONT=verdana,arial,helvetica][SIZE=-1] $118.09 [/SIZE][/FONT] [FONT=verdana,arial,helvetica][SIZE=-1] Shipping & Handling: [/SIZE][/FONT] [FONT=verdana,arial,helvetica][SIZE=-1] $5.23 [/SIZE][/FONT] [FONT=verdana,arial,helvetica][SIZE=-1] Super Saver Discount: [/SIZE][/FONT] [FONT=verdana,arial,helvetica][SIZE=-1] -$5.23 [/SIZE][/FONT] ------ [FONT=verdana,arial,helvetica][SIZE=-1] Total for this Order: [/SIZE][/FONT] [FONT=verdana,arial,helvetica][SIZE=-1] $118.09 [/SIZE][/FONT] [FONT=verdana,arial,helvetica][SIZE=-1]
    Shipping estimate for these items: August 27, 2010 [/SIZE][/FONT]
    [FONT=verdana,arial,helvetica][SIZE=-1]1[/SIZE][/FONT] [FONT=verdana,arial,helvetica][SIZE=-1] "PIAA 15211 H11 Style Xtreme White 55=110-Watt Bulb - Twin Pack"
    Misc.; $63.09
    Sold by: http://www.amazon.com/gp/help/seller/home.html/ref=ox_oce_seller_home?ie=UTF8&seller=ATVPDKIKX0DER [/SIZE][/FONT]
    [FONT=verdana,arial,helvetica][SIZE=-1]1[/SIZE][/FONT] [FONT=verdana,arial,helvetica][SIZE=-1] "PIAA 19615 HB3-9005 Style Xtreme White Plus 60=120-Watt Bulb - Twin Pack"
    Misc.; $55.00
