Replaced Turn Signals, Fog Lights, High Beams, Parking Lights & Rear License Plate Bulbs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by stream, Jun 13, 2009.
  1. hlkc
    hlkc New Member
    229
    US
    Not 100% understanding your question. Gen III is using H11 for low beam and fog light.
  2. Tideland Prius
    16,553
    As long as you replace it with the same type of bulb.
  3. WE0H
    WE0H Senior Member
    3,247
    528
    Maybe this will help. There are adapters that go between the ballast and the harness to make the car's computer operate the HID lamps properly.
    Quote from eBay ad...
    Auction # 320492759810
    Product Description
    This Listing is for Two pieces of HID Xenon kit Computer Dashboard Panel Error Warning Light Canceller (Capacitor). *100% Plug&Play*
    • The decoder will works with all aftermarket HID xenon Kits: H1, H3, H4, H7, H8, H9, H10, H11, H13, 9004, 9005, 9006, 9007, 880, 881, 889​
    • This harness has the resistors & capacitors to simulate a factory Halogen Bulb. This will solve the error message on the dash board of newer luxury cars. ​
    • This harness will also eliminate HID headlight flickering that is caused by the Vehicle's computer not recognizing the low wattage HID bulb. ​
    • This HID Conversion Kit Computer Warning Canceller will solve the computer error warning encountered during the installation of the HID kits. ​
    • Power from the vehicle factory headlight plugs into this harness and this harness powers your HID Ballast.
    • This cable will work for all CARS WITH COMPUTER CONTROLLED HEADLIGHTS, including such car models as Benz, BMW, Audi, ACURA, Chevrolet, Chrysler, Dodge, Ford, Ford Honda Jeep, Mazda, Mercedes, Benz, Mitsubishi, Nissan, Pontiac, Saturn, Subaru, Suzuki, Toyota, Toyota Truck, Volkswagen, Volvo, CORVETTE, Hyundai, Sonata, Plymouth, voyager, HONDA, CIVIC, TOYOTA, CAMRY, LINCOLN, NAVIGATOR, FORD, EXPEDITION, FORD, EXPLORER Jeep, Wrangler, Pontiac, Grand, Prix, Nissan, Altima / 240sx ACURA INTEGRA toyota.
    • This cable is 100% Plug & Play, Very Easy to Install; no modification is needed.
    • Bulb type: 35W​
    • Volts in: 9 to 16V​
    Hope this helps :)
    Mike
  4. cupidchild
    cupidchild Junior Member
    89
    Denver
    I went to PowerBulbs.com to purchase replacement turn signal bulbs size WY21W but they are not available. :(
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    You can also get them here--I've bought from this company in the past:
    Philips WY21W Silvervision
  6. hlkc
    hlkc New Member
    229
    US
    I got the same bulb and I like it so far. But Please don't expect it is completely 100% orange free. In most angles, you don't see the orange surface. But from time to time when I walked by I do see some orange here and there probably from the reflectors...
  7. cupidchild
    89
    Denver
    Its so expensive. $24 for pair of bulb.
    Ebay isn't any better at $22.99 + $5.99 shipping. :(
  8. shaun5stu
    shaun5stu Junior Member
    61
    Chandler, AZ
    I know this isn't really an LED thread, but my question involves changing the four marker lights (clear and amber over the headlights). I've got the LED replacements and I was able to change the clear marker light on the driver's side. The others though, I simply can't get to. Besides having next to no mechanical aptitude, I recently sliced my left thumb badly and have a hard time doing any work with that hand (I'm left handed). If I take the LEDs to the dealer, what are the odds they will replace the bulbs for me? Alternately, is there anyone in the Phoenix are willing to help :)
  9. cupidchild
    89
    Denver
    I'm not in Phoenix area to help you. :(
    Replacing Clear maker light (top of low beam) on passenger side is pretty easy as well, you just need to remove one 10mm screw and lift of the hose and white plastic thing (I believe radiator fluid?)
    Now the side markers would be abit more difficult.
    I would say, if you can't do it yourself, take it to any near by audio / car modification shops. They would do it for you and for less price.
    good luck
  10. shaun5stu
    61
    Chandler, AZ
    That's what I had read about the passenger side clear marker - which is the only reason I attempted it myself. But I couldn't get the screw undone and the metal flange it was screwed into was bending during my attempts, so I didn't want to try too hard. Also, the white plastic bucket (coolant, I think) is easily unsnapped from the top, but the bottom of it seems connected to a hose that goes down into the engine somewhere and doesn't let the thing move too much. And there is also what looks like an air intake tube that is in my way. That's screwed in place with another screw in a tight area. I don't have a screwdriver short enough to unscrew that one.
    Or maybe my hands are just too big :)
    I did find the amber side marker on the driver's side, but I can't get any leverage on it to remove it with my sore thumb.
    Thanks for the tips about an audio shop!
  11. Bsc12
    Bsc12 New Member
    SF Bay
    Hi stream great post. I just got mine prius two days ago which changing all the lightbukds yesterday like you did I am having trouble install the turn signal lights it seems the razo lights I got will not fit into the slots of the turn signal sockets. Did you have trouble when fitting yours?
  12. stream
    2,977
    452
    Long Island, NY
    I didn't have any issues. What is a razo light?
  13. Bsc12
    Bsc12 New Member
    SF Bay
    RAZO brand from Jap, specialize in after market light buld. Anyway the lights I got from RAZO have no problem fitting into the back up light socket, but when I try to put it into the turn signal socket it will not fit in. I was just wondering if you have trouble fitting yours ( the philips brand). Thank you.
  14. hello_x
    hello_x New Member
    Houston, TX
    I have question about Parking light. I'm planning to install Red led (Red Prius) and I know it's illegal to have red, blue on the front. Question is: Is the light only turn on when in P position and turn off during reverse or drive? Also, is the light turn on when brake (hopefully not)? If so then I guess it will be ok then??
    --hello_x
  15. stream
    2,977
    452
    Long Island, NY
    The parking lights are above the headlights. The are illuminated when the headlights are on, and when the headlight switch is in the first position.
    There's a good reason why it's illegal to have red lights on the front of the car--it's a safety hazard. When you see red lights you assume it's the back of the car.
  16. MyPrius10
    MyPrius10 New Member
    22
    South Florida
    Looks great!
  17. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    Re: PIAA ... doesn't know ... lumen output of 15211's
    Below is my inquiry to PIAA, and their reply, on the output in lumens of the PIAA 15211 bulbs which, among other uses, can fit the halogen - equipped Prius low beams. They aren't saying.
    Does anyone here on the site know what the lumen output of the PIAA 15211 bulbs (which advertise that they yield 55W --> 110W) is so they can be compared with other H11 bulbs?
    RE: PIAA 15211 light bulbs
    Wednesday, June 30, 2010 6:16 PM
    "Service" <[email protected]>
    Add sender to Contacts
    To:
    "'Aegison'" <[email protected]>
    I do not have that at this time because of the standard is not there for the lumens measurement.
    Thanks
    Alan Avery
    PIAA Customer Service
    503-489-6666
    1-800-525-7422
    [email protected]
    -----Original Message-----
    Sent: Wednesday, June 30, 2010 3:10 PM
    To: [email protected]
    Subject: PIAA 15211 light bulbs
    Several of us on an online car forum are discussing use of PIAA 15211 bulbs. Can you please tell us what a 15211 bulb's output is in lumens?
    Thank you.
  18. praecurvo
    praecurvo Junior Member
    34
    Boulder
    I'm sorry if this has been answered already, but I've read and read and not found it yet (it's late). Are there amber LED's available for the front/rear turn signals and red LED's for the rear brake lights? If there are, what are they(where to find) and are they easy to install?
    aaron
  19. Tideland Prius
    16,553
    The brake lights are LEDs. Indicators are available but require a load resistor to stop them from blinking faster (because LEDs use less power so the car thinks that a bulb is out and will blink faster)
  20. praecurvo
    34
    Boulder
    Thank you. Does anyone sell these LED signals with built in load resistors?
    aaron
