Replacement Horn?
Discussion in 'Gen 3 Prius Main Forum' started by Yaesu, Sep 5, 2022.
  1. Yaesu
    Yaesu Member
    106
    31
    Kentucky
    I would like to replace the inadequate sounding horn on my 2010 Prius. Has anyone replaced their horn? If so, what did you replace it with, and were their any changed necessary to the wiring or mounting of the old horn?
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    https://priuschat.com/index.php?threads/88297/
    FYI, you don't have to remove the front Toyota emblem unless your car is equipped with DRCC.
    FIAMM High/Low note horns, in my experience are the best.
    FIAMM 72102 Freeway Blaster HIGH Note Horn https://a.co/fN83YOT
    FIAMM 72112 Freeway Blaster LOW Note Horn https://a.co/39yaeYs
    I tried Hella horns, but they failed just past the 30 day Amazon return window.
    I have installed FIAMM Freeway Blaster horns in 3 cars (2011 Prius, 2014 Corolla, and 2016 Corolla) with no problems.
    You need to have basic electrical experience/tools and will have to add an extra wire to the second horn. Additionally, wire, electrical terminals, wire cutters, terminal crimper tool, and heat shrink tubing or electrical tape are needed.
    It's in the thread linked at the top of the this post.
    #2 xliderider, Sep 5, 2022
  3. Yaesu
    Yaesu Member
    106
    31
    Kentucky
    Thanks. I ordered the Freeway Blasters. My concern was compatibility with aftermarket horns. Years ago I had a couple problems connecting horns to more modern vehicles (at that time), because modern vehicles switched the ground instead of the positive part of the circuit and therefore the horn had to be isolated from the steel body of the vehicle.
    jerrymildred likes this.
  4. xliderider
    7,869
    3,116
    Honolulu, HI
    Nope, the Freeway Blaster horns are grounded via ring terminal connectors under the mounting nut(s) to the negative connector on the back of the horn.
    No separate relay is needed for the Toyota installation.
    Picture is my Corolla, there is an available threaded bolt hole on the frame that is perfect for the second horn. An extension wire runs from the positive terminal from horn closest to the OEM horn wire and the second horn's positive terminal.
  5. xliderider
    7,869
    3,116
    Honolulu, HI
    Here is the picture, couldn't upload it in edit mode in previous post. 20220905_084146.jpeg
  6. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    I have a pair of Freeway Blasters on my '17 Prime and my wife's Prius 2. I installed them immediately after this idiot pulling a trailer completely ignored the little toy horns that are standard in all Japanese cars that I know of.
    xliderider likes this.
  7. xliderider
    7,869
    3,116
    Honolulu, HI
    Yep, just last week, had to put the Freeway Blasters to good use twice in one day.
    They sure wake up the inattentive driver who doesn't check their blindspot before lane changing into my lane. Usually without signaling the move as well.
    #7 xliderider, Sep 5, 2022
  8. Yaesu
    Yaesu Member
    106
    31
    Kentucky
    I think you were in his blind spot and he obviously didn't check over his shoulder before cutting your off. The horn in your car was very feeble.
    All of my motorcycles have very loud airhorns. They all require relays, which I don't intend to do with the Prius.
  9. jerrymildred
    11,508
    14,109
    Tampa, FL
    My last two bike were where I got started with the Fiamms. I made a pickup driver hit his head on the roof of his truck once. He hadn't even glanced in his mirror or turned his head one little bit. And his window was open and he wasn't wearing a seatbelt. (I also used relays and heavier wire on the motorcycles to make sure the horns got full power and I didn't melt any wires. Same with the driving lights.
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,159
    2,207
    Taylors, SC
    Toyota uses a version of these horns branded with their labels in thir premium vehicles and as an aftermarket accessory upgrade.
    Piaa 85110 115db 400HZ + 500HZ Sports Horn
    They work with the current wiring and are a direct replacement of the OEM horns.
  11. Tombukt2
    Tombukt2 Senior Member
    8,980
    1,562
    Durham NC
    I use the compact air horn from the Italian company makes for boats . I want train horn its in garage but it's too large.
