Replacement Timing
Discussion in 'Gen 3 Prius Main Forum' started by Sbk1569, Dec 18, 2023.
Tags:
  1. Sbk1569
    Sbk1569 Junior Member
    AL
    I am the only owner of a 2014 Prius. The car has 185k miles. I have done all the recommended maintenance- EGR cleaned, spark plugs, transaxle fluid replaced and all other fluids replaced. I see the battery test is something I could do. But what is the best practice on replacing the car. When is the right time in general to not lose all its value? I realize there are a zillion directions this could go. What’s the consensus? This is my 4th Prius and the longest I have owned any car.
    52,841
    i'd say right about now. lots of people looking for decent used cars, and new car sales are slowing, so there should be some deals out there.
  3. Mendel Leisk
    42,341
    At what miles did you do that cleaning?
  4. Sbk1569
    AL
    160k the EGR was cleaned
  5. Mendel Leisk
    42,341
    A little late in the day; keep your fingers crossed.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,085
    6,947
    Texas Hill Country
    Replace now for maximum value. Ideally sell private party. If you lose the head gasket the value at a dealer goes to zero; private party maybe $1000. The hybrid battery is actually less of a concern since it could be “fixed” for sale purposes for maybe $1000.
  7. Sbk1569
    AL
    Thank you- should I replace the water pump?
  8. Leadfoot J. McCoalroller
    8,288
    7,800
    Pennsylvania
    2018 Prius c
    If your plan is to trade the car in for its replacement, don't bother. It won't make a nickel's difference to the trade value.
    Might be different for private sale to another individual.
  9. Mendel Leisk
    42,341
    They’ve been failing around 150~200k miles, as reported here.
  10. bisco
    52,841
    might as well do the brake actuator as well
  11. rjparker
    11,085
    6,947
    Texas Hill Country
    Preemptive head gasket and new pistons and rings as well. Seriously if it’s not broke don’t fix it.
    But if this was a needed daily driver and you wanted another three to five years out of it, building a substantial repair fund might make sense.
    Some value reliability over lowest possible cost of ownership. Others believe safety and reliability trumps saving a new car expense.
