Replacement tire recommendations for a Gen II (2007) Prius?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by camner, Sep 11, 2013.
  1. Logangogarty
    Logangogarty Junior Member
    31
  2. Logangogarty
    31
    Found this on the discount tire website "A 91H tire has a load capacity of 1356lbs per tire compared to 1279lbs per tire on an 89H. It is not recommended to mix different ratings on the same axle of a vehicle."
  3. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    As you have found out the number is the load rating for the tyre, the following letter H is the speed rating.
    John (Britprius)
  4. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Over 137k miles I've had the following tires.
    Stock Integras - short lived, nothing spectacular.
    Michelin Hydroedge - great dry or wet, forget about ice.
    Nokian entyre - great winter tire labeled as all season. Short lived.
    Bridgestone Ecopia EP422 - love these. Quite, smooth, improved millage, good wear, good all around performance including snow. I will go with these again.
  5. Logangogarty
    31
    Well I would have loved to buy the ecopia EP422 in the 205/55/16 unfortunately costco would not install them because I have the touring edition and on bridgestone tires you can't go below the speed rating which is H in the 205. I had to get the 195 because they had a higher speed rating which makes no sense to me. I'm going to get the other two replaced tonight but I'm considering trying to return the 195s and getting a different tire all together in the 205 because I really wanted a little more clearance for my driveway.
  6. Britprius
    5,194
    1,924
    Surely the the EP422's are available in other speed ratings. In the UK/EU standard road tyes are available in all speed ratings except perhaps the very highest where much larger tyres are required anyway.
    H is rated at 130 mph, and the Prius only does 112 mph
    John (Britprius)
