Replacement tires
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by IABoy987, Jun 10, 2015.
  1. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    understand these tires last well, so if they get loud you will have to put up with it for awhile. Think I would go the energy saver route. H
    IABoy987 likes this.
  2. mrajdstp
    mrajdstp Junior Member
    25
    St Paul, MN
    Can you give more details re snow & ice handling? Thx.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    We avoid deep, unplowed snow, but otherwise the tires work fine on packed snow. We avoid ice/wet slush also. We have the luxury to stay home when conditions get too extreme.
  4. mrajdstp
    25
    St Paul, MN
    Yup, the Prius is not much of a deep, unplowed snow car. Not enough clearance.
  5. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you want great MPG and performance in ICE/Snow take a look at the Nokian WRg3 tires. I'm just finishing up wearing out my third set of Nokians (WR, and 2x WRg2, each lasted about 50k miles) and they have been great. I had previously had a set of Michelin MVX4+ (an older model, good mpg and performance, but not a match for the Nokians). There is a set of Nokians on my wife's Jetta just to get good traction in bad weather.
    JeffD
    Ajrob671, IABoy987 and HaroldW like this.
  6. mrajdstp
    25
    St Paul, MN
    How are the Nokians on gas mileage?
    iPad ?
  7. jaglio16
    jaglio16 Junior Member
    North Bellmore, New York
    The Nokians are great. I drive the WRG3 year round and haven't seen a dip in MPG at all, and they were great in the NY snow this past winter.
    iPhone ?
    #27 jaglio16, Sep 5, 2015
  8. jdenenberg
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Nokian WRg3 tires are LRR rated and get better average MPG (about 2 to 3%) than the OE Goodyear tires (most of the improvement is in cold weather MPG when the non LRR materials stiffen).
    JeffD
  9. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    So it appears from tabulating responses, Either Michelin Premier or Defender XT are top, with Michelin Energy saver second.
    Read up on LRR in wikipedia to understand how it affects tires.
    Like Mendel Leisk says: Now I am torn/confused! Any tires will work, its just getting ones that "stick to the road" and do well on Iowa snow and ice. So may have to take the MPG hit to get best results.
    But I had better decide, Winters coming!!:eek:
  10. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Local Sears store sells Michelin tires, but there was a whole two pages listing the tires. What tires are made to fit Prius?
    In other words, I read a whole bunch a numbers and letters after the type but don't know how to parse the list to get just ones that fit Prius. Some Michelin tire pictures look like tires for 4x4 or vans or trucks so they can be eliminated but still left others that could work.
    Help educate me on deciphering the code, please or point me to a website that can help me.
    Thanks!!
  11. lester williams
    227
    68
    mississippi
    Factory size is 195-65-15'', see what they offer in that size to help narrow it down. My tire of choice is the Premier, a set on both autos.
  12. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Like Lester, I have the 195/p65R15. I figured out the R15 was 15" rims, but unsure of the first two set of numbers and whether increasing numbers is good or bad.
    Sears lists 195/65R15 91T, 195/60R15 88H, 195/60R15 88T, 205/65R15 94T, P235/75R15 108T and on and on.....:(
  13. lester williams
    227
    68
    mississippi
    The first number, ''195'' is how tall a tire is. The second, ''65'' is tread width, and 15 represents the wheel diameter. The letters ''T'', ''H'' represent the speed rating of the tire-- 110 mph, 129 mph, etc. Look on a chart on Tire Rack's site and there is speed rating charts. Also, that has to due with tire construction as well, how ''beefy'' they are. A lower speed rating will probably ride smoother, they are not as stiff.
  14. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    No! "195" in that example is the overall width of the tire's cross-section, and "65" is the ratio of height to width, as a percentage. Multiply those two numbers and divide by 100 to get the nominal cross-sectional height, about 127 mm in this example.
    Merkey likes this.
  15. Mendel Leisk
    42,293
    And then get 195/65R15, lol.
    Lotsa sites, TireRack for one, allow you to feed in your car info, then show you the appropriate size, speed rating and so on.
  16. lester williams
    227
    68
    mississippi
    We had another thread about being old and senile,,,,,, I have a good excuse......3 days of sitting beside wife's hospital bed has skewed my thinking-- along with being old and senile... [ and,, you are right-- I knew that...]
    CR94, Merkey and Mendel Leisk like this.
  17. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
  18. Mendel Leisk
    42,293
    Lester, best wishes for your wife, speedy recovery.
  19. LDB
    LDB Member
    279
    71
    Friendswood (Houston south suburb)
    tirerack.com is an excellent research site.
    The 820 rating on the Michelin is excellent but can only be compared with other Michelin tires. Each brand sets their own scale so a Michelin 820 may be the same as an Acme 650 and a Widgets 490.
  20. Mendel Leisk
    42,293
    Screw Michelin, I'm gonna get me a set of them Widgets. :)
