Replacement TPMS Sensors
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Brady B, May 9, 2017.
Tags:
  1. Brady B
    Brady B New Member
    Richmond, Va
    2014 Prius c
    I recently had a tire with a nail in it that i got plugged at a local tire shop. It started leaking again after a few months so i took it in to get patched, as the tire's were otherwise in perfect condition. When they took the tire off the rim this time, it turned out the TPMS Sensor had broken off in the tire, likely from driving a day or two with leaky pressure and just filling up at the gas station as i assessed what was going on.
    In any event, i need to get ONE new TPMS Sensor. I've been having a lot of trouble telling if ones i find online are compatible and the ones from the dealer and even NAPA are pretty expensive.
    Has anyone here had good luck replacing an after market TPMS for a decent price on their Prius C and care to share?
    Dualblue likes this.
  2. valuequest
    valuequest Junior Member
    southeastern Virginia
    I recognize that I am bumping an old thread, but I am quite interested in the topic as asked.
    My local Walmart Auto Service claims that they can replace a TPMS sensor with one that they have in inventory. I am curious... has anyone had a Walmart Auto Service actually replace a TPMS sensor successfully?
  3. valuequest
    My local Walmart Auto Service did replace the one TPMS sensor that had gone bad with this product.
    manufacturer: Bartec USA
    part number: RS-2000R
    apparent marketing name: RiteSensor (copyrighted)
    The change of signaling from the dashboard indicates that they apparently successfully programmed the replacement TPMS sensor above into the Prius C's TPMS system.
    Total for the replacement before state tax: $28.88
    Brian1954 likes this.
