Replacing 12-volt battery cathode
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ThePrius11, Jun 29, 2023.
  1. ThePrius11
    ThePrius11 Junior Member
    16
    Tbilisi, Georgia
    I
    Hi everyone
    Could I just replace the cathode instead of buying a new 12v battery?
    The car shut off twice while driving and the power steering also went off due to this :((
    Thanks for your input
    52,857
    are you sure it's a 12v problem?
    ThePrius11 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,465
    5,432
    Pacific Northwest, USA
    Looks like this battery has had issues in the past and they already replaced the terminal the battery connects to... Not sure what's wrong with the battery but they are sealed and maybe if you lived in rural India there would be someone who rebuilds them but not anywhere else as its toxic and messy.
    Once you get the 12v replaced you may solve the problem with the car, or you may not. Too soon to tell. But it certainly is the first step.
  4. ThePrius11
    16
    Tbilisi, Georgia
    I
    Not anymore after reading some other threads on this forum. It might be either the 2018 recall (18V684) or the hybrid battery. The car, along with power steering, went off a couple times after I updated the software in a local dealership. So it might have shut off due to the inverter failure. I also need to replace half the hv battery modules so it could be due to that, or maybe both.
    Good question, anyway :)) Thanks for your reply. I shouldn't have posted this before reading other threads.
  5. ThePrius11
    16
    Tbilisi, Georgia
    I
    Thanks for your reply. You're right. I'd rather replace the battery :))
  6. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    OUCH! It that post is that bad, the rest of it is also, and so are the cells.
    Get a new battery....
  7. ThePrius11
    16
    Tbilisi, Georgia
    I
    Thanks, ASRDogman. I definitely will. I've had enough with this battery
    ASRDogman likes this.
  8. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    If you're in a place where they do things like that have at it here where I am they don't do too much of this kind of thing.
