REPLACING 12V BATTERY
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hotrod, Jul 6, 2018.
  1. hotrod
    hotrod Junior Member
    sarasota fl
    We recently had our 12 volt battery replaced which involved getting towed to dealer and all that krapp! after it was replaced for a sum of about $300 dollars, i went to utube to see what was involved. first, the battery was 25 months old. dealer said it is a 1 year warrantee deal. the replacement is looking rather easy as viewed on the videos. so, next time, i'm buying a battery from a local auto parts place and do it myself. like some other cars these days, it appears there isn't any recalibration or resetting anything. tell me if i am incorrect here
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Lots of folks replace their own 12 V batteries.
    Sometimes finding an exact replacement is a bit difficult.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    They probably had to reset the clock...
  4. Mendel Leisk
    42,384
    You might need to get it to "relearn" the window auto-up function. IIRC, you run the window down, then up, holding the switch up all the while till it's up, then an additional 2~3 seconds.
    Yeah, Pep Boys sells a compatible Bosch battery, dimensionally identical, proper posts, vent port, spec's. It goes on sales sometimes for around $145. They'll install it for that price, but it might be preferable to do it yourself, DIY you tend to be more careful and thorough, clean the clamps for example.
  5. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    You might have to reset your radio station, clock, as FuelMiser said.
    If you a have a 12v battery that you can hook up to the jumping point under the hood, you shouldn't have to
    do anything when you replace the battery. Just cover the positive terminal so it doesn't touch ground! OUCH! :)
  6. bisco
    52,922
    finding an exact replacement is easy, there are 4 or 5 on the market now.
    i think the dealer is wrong about the warranty, i would delve further into that. i know the new one is 2 year full replacement, then several years pro rated.
    Bay Stater and Mendel Leisk like this.
  7. Mendel Leisk
    42,384
    There's a gizmo for connecting jump packs to the OBD port, for providing volts during battery replacment. Here's one example:
    Google "Clore Memory Saver Connector"
    Tande, Bay Stater and jerrymildred like this.
  8. hotrod
    sarasota fl
    thank all of you for your input. it has been a big help! the most important part is stay away from the stealer!
  9. Mendel Leisk
    42,384
    The hold-down bracket over the battery is an odd-design, intolerant of any variation in battery height. I found when I swapped in an Optima Yellow Top, even though spec'd height was the same, it was slightly higher, and I had to resort to a shim washer under the bracket at one side.
    A more typical hold-down bracket has these long hook bolts with generous threading for nuts at the top, will accomodate plus/minus 1/4" in height variation.
    Bottom line: if you're going to DIY a swap in a store parking lot, bring a few washers, appropriate for the bolt diameter.
  10. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    The prius tend to trickle charge the aux battery, it’s always in need of a full charge, a good idea is to once a month, after checking the air pressure, hook up your 2 amp trickle charger overnight, top up the 12v to keep it healthy.
    Because the battery is in the cabin and not in front with the motor, it’s a sealed battery, and must be replaced with a sealed battery, the oem battery is minimal, Optima makes a yellow top, sealed, deep cell (rechargeable) battery that fits in the prius, the optima also needs a monthly top up.
    So keep your tires between 40-50 lbs, keep the cabin air filter clean and top off the battery monthly.
  11. Mendel Leisk
    42,384
    The OEM battery is no slouch, typically a Yuasa: I believe it has higher "amp hours" than the Optima. It can be pricey though.
  12. CR94
    CR94 Senior Member
    2,844
    1,246
    Northwestern S.C.
    My U1 AGM battery cost $65 new, is almost 3½ years old now, and is still functioning well.
  13. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    My battery is over 5 years old. How can you test it to find out if it's still good? I'd rather replace it before it fails. It's given no indication that it's bad.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    They usually don't give any indication before they fail.
    With conventional cars where the 12 V actually cranks the engine, you might notice that it was cranking slowly.
    Not so with a hybrid.
    Most any place that sells car batteries can test it.......but when it's over 5 years old, it might test good today and fail tomorrow.
    Time to get a new one while you can do it on your own terms.......instead of calling AAA from the side of the road.
    Merkey likes this.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Easiest way is to check the battery voltage after sitting overnight.
    Once you have that, you can see what the voltage is and of above 12.5 volts, you should be good for awhile.
    Getting a battery maintainer helps increase the longevity of the battery.
    Just retired our 2010’s original 12 volt January 2nd of this year after 8.5 years in service.
    If you have never drained it, keep an eye on the voltage and you should be fine.
    #15 Raytheeagle, Aug 3, 2018
    Merkey likes this.
