Replacing 12v with LiFePo4-4S
Discussion in 'Gen 3 Prius Technical Discussion' started by abubin, Dec 4, 2024.
  1. abubin
    abubin Member
    193
    92
    Malaysia
    I have build a LFP4 12v battery pack with a BMS that can handle charging 20A and discharging 40A.
    Will it be sufficient to use it on a gen3 Prius?
  2. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Good luck in temperatures colder than 32F with that battery chemistry.
  3. ASRDogman
    ASRDogman Senior Member
    8,036
    4,073
    ???:confused: Why??? They're are already dozens of batteries out there....
    If you were going to mass produce it and sell them for $50, okay.
  4. abubin
    abubin Member
    193
    92
    Malaysia
    No worries. I am at a place with summer 365 days.
  5. abubin
    abubin Member
    193
    92
    Malaysia
    This was built for my solar learning project. So I figured might as well try it out on a Prius. Do take note, I am currently using a factory made 12v LFP4 battery without any issues. Just want to see if the one I built will work with those charging/discharging parameters.
    ASRDogman likes this.
