Replacing 2 Cells
Discussion in 'Generation 1 Prius Discussion' started by Bruce Berquist, Sep 9, 2021.
  1. Bruce Berquist
    Bruce Berquist Junior Member
    95
    26
    South Tamworth, NH
    2003 Prius
    I
    I am getting a couple of Torque Battery trouble codes of unbalanced cells and broken connection(s).
    Actually the only two Trouble Codes that come up now on my 2003 Sedan restoration project after I fabricated and installed a new cat and exhaust system.
    I pulled the cover and terminal rails off of the battery assembly and found a lot of corrosion on the rail terminal connections and a broken corroded wire in the terminal to the Battery Control Computer. Serious enough that I ordered new rails.
    Painstakingly, I have tested each and every cell. Trickle charged a small number of low cells to 7.8+v and they are holding charge at a nominal of 7.6v+/-, as with all the other good cells.
    However there are 2 cells that easily take the charge to 7.8+ volts but then, with in 30minutes, discharge down to 1.3v and 3.6v.
    I am assuming that this is a non-serviceable issue for these 2 cells and that I need to replace them.
    I just ordered 2 gen 1 replacement cells.
    So it's now off to another phase in my adventure of restoring my "Little Blueberry" 2003 4 door Sedan.
    Any and all input and advice will be greatly appreciated.
    #1 Bruce Berquist, Sep 9, 2021
    mroberds likes this.
  2. AlexY
    AlexY Member
    163
    45
    UK
    Correct, 2 packs dropped under 6V are dead. Ideally if you can perform complete battery balance charging using high voltage (~350V DC) with small current limit like 100mA, usually 350mA is used but I believe capacity of your packs is down to something around 3Ah so that would not be safe.
    mroberds and Bruce Berquist like this.
