Replacing 3rd Gen Spark Plugs
Discussion in 'Gen 3 Prius Technical Discussion' started by R1CH13, Sep 5, 2014.
  1. bisco
    52,828
    well now you've got me reconsidering, i wouldn't mind a smoother shifting transmission...
    HaroldW and milkman44 like this.
  2. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    You could always recycle the plugs. Clean them up, re-gap them, and put them back in. Of course you do run the risk of the insulator seal failing from heat cycling (because you would be heat cycling them for the equivalent of much more than 100,000 mi). Sometimes they can drop into the engine when the ceramic fails. That can get expensive!
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Note to self for 2020: change PCV and plugs when I change the struts.
    I don't want to waste 45 minutes of my life with the disassembly involved more than once in the car's lifetime if I don't have to. ;)
  4. gliderman
    gliderman Active Member
    751
    225
    Thats interesting! My Prius transmission never shifts. Hmmmm?
    Oh! I think it does in my Ford F-350. I will have to change the spark plugs and see if it shifts smoother.
    seeker311 likes this.
  5. bisco
    52,828
    you have to read post #16.;)
  6. JC91006
    16,936
    8,647
    Mine came with a 6 speed but I can't feel it
    seeker311 and Friend of Bill W. like this.
  7. bisco
    52,828
    you must have special plugs.(y)
    nssdiver likes this.
  8. gliderman
    751
    225
    I read it when it was posted. My tranny doesnt shift any more. Or any less. :whistle:
  9. bisco
    52,828
    my poor attempt at humour.:)
  10. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    i thought it was a good attempt at humour! h
  11. CreigMac
    CreigMac Junior Member
    Anchorage Alaska
    I pulled my Tundra plugs at 120K miles and they looked 90% as good as the new ones I put them back and used them till 140K. When I changed them the trucks behavior didn't change a bit MPG's stayed the same. Not sure how heat cycling will affect the Prius plugs but I'd imagine 120K is easily attainable. 10 years from now plugs will be a lifetime item if things keep going the way they are.
  12. R1CH13
    R1CH13 Member
    Michigan
    You guys do know when I meant shifting I didn't mean the transmission right? I was talking about the transition from electric to gas and vice versa. Since you guys like being technical. The Prius TRANSITIONED from electric to gas better after I replaced the plugs.
    ftl likes this.
  13. bisco
    52,828
    i was just yankin' your chain.:p sorry man!:)
    #33 bisco, Sep 9, 2014
    R1CH13 likes this.
  14. gliderman
    751
    225
    Yeah we knew. I think. (y)
  15. qdllc
    qdllc Senior Member
    1,377
    400
    You mean the one in the CVT, right? :sneaky:
    Danny3xd and bisco like this.
  16. djs
    djs Junior Member
    NW WASHINGTON
    Nice video on how to remove a bunch of parts, and although I haven't needed to replace spark plugs, I remove the plastic plug cover every time I change oil just to clean things up and it just comes off easily with out the need to remove anything else. I haven't check recently to see if there is enough room once the cover is off to remove the plugs but visual memory suggests there is. The video indicates you have to remove all that gear just to remove the plastic cover. That just isn't so on my 2010.
    gliderman likes this.
  17. Mendel Leisk
    42,330
    The video method, unfortunately, is the only way to get the at the plugs, get them out. I've done it.
    It is really frustrating: without all that disassembly, you can get at the ignition coils, get them off, and then there's metal sleeve going down into the spark plug well. Pull it up, it comes up about 2 inch, and then bump, hit's the underside of the bodywork. :(
  18. GregP507
    GregP507 Senior Member
    3,002
    481
    Yeah, if you spent more money, it has to be an improvement.
    :rolleyes:
  19. priusde
    priusde Junior Member
    28
    DE
    Replacing plugs over the weekend but what a pain.
  20. 48mpg
    48mpg Member
    193
    47
    florida
    I
    WOW, just WOW! makes me want to pay someone to do it
