replacing a bad cell do i need to balance all cells ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ids381, Feb 9, 2018.
  1. Prodigyplace
    12,712
    11,848
    Central Virginia
    Block 10 is weak and, I believe block 6 may be starting to have problems too. Or, the pack may just need reconditioning (careful deep discharging & recharging). It is difficult to tell.
    @TMR-JWAP here has done a lot of battery testing & evaluation in his hobby. He could better inform you.
  2. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I am in same situation. The car is not going to HV mode. The engine runs continuously. Were you able to fix it?
  3. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    What situation is the same? What car are you talking about? "The car not going to HV mode" and "The engine runs continuously" is not really useful information.
    Generally, it is not a good idea to tag onto someone else's thread (which is called hijacking) and if you want to diagnose your car you should start your own thread in an appropriate forum and begin by stating what codes your car has.
    #23 dolj, Nov 13, 2023
  4. Brian1954
    Brian1954 Senior Member
    2,674
    1,071
    South Central PA, USA
    He did create a thread for his problem. Take a look at this link: https://priuschat.com/index.php?threads/245008/
  5. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    First, I didn't hijack his thread. Also I only asked if he was able to fix it.
    Generally, it’s good idea to read everything what someone has posted before becoming keyboard warrior.
  6. dolj
    dolj Senior Member
    8,646
    4,397
    SFO likes this.
