Replacing a corroded bolt
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobbintb, May 24, 2022.
  1. bobbintb
    bobbintb Junior Member
    22
    I've been having issue with my 2012 Prius, the whole engine shutter thing. So I did all the recommended stuff, clean EGR valve/pipe/cooler, replace PCV valve, replace spark plugs, and clean intake manifold. I forget the name of the part, but I believe it's the air intake system, right before I remove the intake manifold. Anyway, two of the four bolts are corroded. One actually broke. They are M6-1.0 x 50mm flanged hex bolts and half threaded. Oddly, I'm having a hard time finding them locally. I have only found some fully threaded ones at Home Depot. I haven't asked the dealer but now I'm wondering if I should replace them with something sturdier. There was a lot of oil in there that I had to clean out and I suspect that caused much of the corrosion. I guess it was Zinc plated because it was white. Any suggestions? Should I see what the dealer has? Find something more corrosion resistant?
  2. ChapmanF
    15,557
    Throttle body?
    As the picture shows, some cars used four bolts (91551-80650), and some cars used two of those and two studs with nuts.
    I would just head for the dealer and ask for a couple 91551-80650 bolts and call it a day. Some things aren't worth the trouble to scrounge up substitutes for, even if it's a pretty easy scrounge.
    jzchen likes this.
  3. bobbintb
    22
    Yes, I believe that's it. I did notice the difference as the NutzAndBoltz video had the two and tow while mine had four. Probably a good idea. This things had been taken apart for far too long as it is. Thanks.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Edit: posted in wrong thread.
    #4 xliderider, May 24, 2022
