Replacing a cracked front turn signal housing in a 2010.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Boffin, Apr 14, 2019.
  1. Boffin
    Boffin Member
    43
    65
    Maryland
    The official manual claims you need to remove the front bumper to do this.
    You don't.
    1) Remove the wheel on the side of the broken turn signal. (Obviously, you'll need to jack up this side of the car to do this)
    2) Remove the wheel well liner. A few 10 mm bolts, but mostly plastic fasteners that can be removed with a couple of small, flat bladed screwdrivers. I only needed to free up the front of the liner. It's plastic and once you've removed enough of those fasteners, it'll fold out of the way nicely.
    3) Scrooch under the car and pull the 10mm nut holding the fog lamp (or the cover for the non existent fog lamp). This cover can stay in place, but it makes things a bit easier to pop it out now. Unclip the wire going to the turn signal light. You'll have to pull back the plastic claws that hold it in place, but this isn't too hard.
    4) The turn signal housing is clipped into the bumper by 3 clips on its corners. Bend the clips inwards (strong fingers or a screwdriver) and work the housing out. BTW, every time I get up close and personal with the underside of a car, dirt invariably rains down on my face. A good pair of safety glasses is pretty much a must.
    Replacement is the reverse of removal, and easier, too. The new housing just snaps in, as does the wire to the turn signal bulb. Remember to replace the fog light or fog light cover, and replace the 10mm bolt holding it all together. Then do the same for the wheel liner and wheel, lower the car, and you've just saved yourself around $100 - $200 in body shop labor.
  2. Mendel Leisk
    38,981
    Thanks for this. (y)
    I always think if the Repair Manual was telling you how to pee, it would require removing your pants. :rolleyes:
    RMB and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,484
    Bay Area, California
    2019 Prius Prime
    They would have a illustrated diagram too:oops:.
    RMB, Grit, CR94 and 3 others like this.
  4. FnRedPrius
    FnRedPrius Active Member
    100
    120
    Pilot, NC
    Left or Right handed threads and would a torque wrench be involved?
    Raytheeagle and Mendel Leisk like this.
  5. FnRedPrius
    100
    120
    Pilot, NC
    Ok, I forgot the Anti-Sieze.
    CR94 likes this.
  6. PriusLarry
    PriusLarry New Member
    Massachusetts
    Thanks for posting this. You likely saved me some work.
    I found I didn't even need to remove the wheel, jack up the car, or climb under it. I just removed the engine under cover bolt and clip (as shown in the Owner's Manual for replacing the bulb) and the one pin and screw from the front of the wheel well, all while sitting on the ground next to the car. That got me enough access to replace the turn signal assembly.
    Unfortunately the one I bought wouldn't go all the way in. I bought an NSF certified TYC part from RockAuto listed for my 2010 Prius, but the "washer" attached at the base of the stud that holds the nut was too large (much larger than on the original part) to fit into the hole in the plastic that's part of the fog light cover, so the lens protruded a bit from the front of the bumper. I ground the washer down with a Dremel until it would fit in the hole, and then it worked fine.
    Taxi/Limo and Robert Holt like this.
  7. Grit
    Grit Senior Member
    6,160
    4,064
    Wilkes Land
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
  8. Taxi/Limo
    Taxi/Limo Active Member
    509
    107
    I hope this thread isn't dead I need to replace the front left turn signal on my 2010
    Do I need to replace the grey piece that is under it too or can I keep the grey piece that is on there ?
    Thanks
  9. Boffin
    Boffin Member
    43
    65
    Maryland
    Taxi/Limo,
    I didn't replace mine, and a year later, no problems.
    Taxi/Limo likes this.
  10. ASRDogman
    ASRDogman Senior Member
    6,284
    3,351
    The grey piece is where the fog lights go. It's just a cover plate if you don't have fog lights
  11. Taxi/Limo
    509
    107
    Thanks guys
    What is a good source to buy a turn signal assembly good quality ?
  12. ASRDogman
    6,284
    3,351
    I would check online for different junk yards around the states.
    I'm certain one of them has one.
  13. Hairy Cannonball
    Hairy Cannonball New Member
    South Dakota
    I know this is an old post, just wanted to thank you for the information. Easy peasy!!! Why anyone would remove the whole bumper cover to do this is beyond me.
  14. Hairy Cannonball
    South Dakota
    Again, i know this is an old post, and I assume you, by now, found a suitable turn signal assembly. I will offer this, new, from the dealer, the genuine Toyota part is not expensive, is original genuine quality, and obviously perfect fit.
  15. Taxi/Limo
    509
    107
    What and where is the engine undercover bolt?
    Thanks
