Replacing Battery for 2006 Prius to Lithium Ion
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Firefoxyoshi, Apr 10, 2017.
  1. Firefoxyoshi
    Firefoxyoshi New Member
    Annapolis, MD
    See, that is interesting and I'm glad a lot of you have such helpful information. The mechanic in question seems like they want to replace the entire nickel battery and put in a lithium ion one. But it seems it's a lot more than just that...
    Yeah I'm definitely going to try looking into replacing the battery or the cells myself with a friend before I really consider purchasing another one.
    Also, I just checked the 12V, it hitting around 11.9v without the engine on, once it is on it hits around 14.4v. I also figured it wouldn't be that since as soon as I turn my car on it goes straight to the gas engine instead of the quiet hum from the hybrid battery. But thank you for the suggestion, I would try anything at this point to see if it's anything instead of the hybrid battery itself.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Replacing with lithium would be great.
    Even if the cost were double what you mention.
    For me, I'm most interested in how they are fooling the car into accepting lithium. I have lots and lots of automotive lithium batteries, would be great to put them to use in a Prius.
  3. Firefoxyoshi
    Annapolis, MD
    Yeah, I have no idea... But it seems from what a lot of you here are saying that it may not be good idea to go with them and instead go with a dealership or find a new nickel battery and do it myself (or just get new cells).
  4. Priii
    Priii New Member
    I heard Toyota was selling rebuilt batteries for around $1500 with a 1 year warranty. Also have seen services that come to you and replace your battery with a known good battery for under $1k...look on eBay.
    SAMSUNG-SM-N910A using PriusChat mobile app
    JohnLS likes this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    Seems like the safest bet is the new battery. Cheapest is the diy repair and a grid charger. Most adventurous learning experience would be the lithium transplant. It might be a disaster, or it might be amazing. Either way, we'd know more than we know now, but it's also the riskiest bet.
  6. Priii
    Priii New Member
  7. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    Really?
    You the best buying from a random guy on ebay that can't even spell the world cycled properly is the way to go?
    LOL
    strawbrad and bisco like this.
  8. Priii
    Priii New Member
    It's an option, there are other options on ebay also. My battery is fine in my 2010. If I had to replace it, I would buy the used / refurbished one from Toyota.
  9. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    The used refurbished from Toyota re only in a very limited California market and right now as far as I see they are on backorder. As if they aren't really even fulfilling the orders? It has looked that way since I've been checking on it since earlier this year.
  10. bisco
    52,891
    while this is correct, it's only 1% of the story. new cells don' play well with the existing ones. so for a decent refurb, a huge amount of time is necessary to rebalance everything. his drives up the cost considerably.
  11. bisco
    52,891
    you need a new 12v.
    jerrymildred likes this.
  12. Firefoxyoshi
    Annapolis, MD
    How so? Everything in the car runs just fine, and there's no real reason to show that it's not working properly, outside of the whole hybrid system not working, which I've already had diagnostics tests run on and they've said it's two cells in the main battery.
    From what I can tell, the only reason to get a new 12V is when it drops very low, which it is .1 under 12 when the car isn't on, and then ~14 when turned on.
  13. bisco
    52,891
    a new one is 13+, so, eventually, you may find yourself stranded.
  14. jerrymildred
    11,517
    14,171
    Tampa, FL
    IIRC, you said it was 11.9V. That's way low unless something discharged it. The 14V while running just tells you that your inverter is feeding 14 volts to the 12V battery as it should.
    Here's a pretty good explanation. Ignore the part about revving the engine if you don't have a multi meter. Very hard to do on a Prius and wouldn't help anyway. How to Test Your Auto Battery | Battery Testing & Maintenance | Autobatteries.com Without a good 12V battery it's really hard to figure out what else, if anything, is wrong.
    I once found that my 12v was down to 8 volts. Only problem was that the accumulator pump was slow to build pressure when I started the car. You never know what will happen with a low 12V battery.
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    There's absolutely nothing wrong with Lithium Ion batteries. BUT...
    It's uncommon, untested, untried and unknown to the point of being nearly Pioneering to have a Nihm to Ion swap. I certainly would be incredibly hesitant about any shop saying they could do it, or even would do it, and especially for only $1700. Testimonials? Evidence of track record? Experience?
    As pointed out, it wouldn't even necessarily be about the physical change...it's that the entire system, software included is designed to work with a NiMH battery. I'd be very dubious that it could be as simple as swapping out the one for the other. I'd be worried that anyone thinking they can would be either incompetent or ignorant to the reality of the challenge.
    Plus the fact that in the original post, we are NOT just talking about a battery swap but also..."making me a plug in prius".
    $1700 for not only a NiMH to Lithium swap but also a standard to plug in conversion?
    No...something isn't right about the whole thing. Something sounds very, very wrong.
    JohnLS likes this.
  17. Rmay635703
    Rmay635703 Senior Member
    2,705
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    About 40 Caddy ELR batteries sold out of junkyards for $900 ish each last year.
    No idea how many are needed to motivate a Prius but if the BMS interface is cheap enough and you can get more than one cars worth from a pack I could see it.
  18. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    Those are some huge batteries. It sounds like an interesting project. How did you find sales data for salvage yards? I searched my resources and can't find a single one. I'd buy one just to bust it open. Wiki shows that only 2958 total cars were sold in US and Canada before production stopped.
    Calendar Year
    Total sales United States[37][38] Canada[34]
    2013
    10 6 4
    2014 1,354 1,310 44
    2015 1,049 1,024 25
    2016 545 534 11
    Total 2,958 2,874 84
  19. edthefox5
    10,096
    4,840
    Clearwater, Florida
    I believe last time I talked to Todd at tampahybrids.com he said he had a G2 with lithium battery's in it for sale.
    Maybe he can weigh in and call me crazy lol.....
  20. bisco
    52,891
