Replacing brake fluid and bleeding brakes on a GEN II Prius without Techstream
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by zak.kapoor, May 3, 2015.
  1. Paul E
    Paul E Junior Member
    FL
    THANKS !!!! THANKS !!!! THANKS !!!!
    I just replaced the ABS actuator pump with a used one from eBay. I looked into getting a Techstream cable and program, but was turned off by the software requiring old versions of Windows. Also, I prefer not needing some remote person fixing the install.
    I removed the bad ABS pump, installed the eBay pump, and bleed the brakes following these instructions. One caveat, I had no helper other than my umbrella against the seat and on the brake pedal for the final bleed and bleeder lock. I bleed about 8 oz out at each brake bleeder just to be sure (I had a quart of brake fluid). Everything is working great!
    rogerdpack and SFO like this.
  2. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    I installed mine on a windows 10 netbook. It is a single core though. Either way there are ways to install it on newer machines
    SFO likes this.
  3. Raul Tejeda
    Raul Tejeda New Member
    Temecula
    Hello Everyone!
    I’m new here and need your help with a couple of questions, please advise?
    First, the way the original poster placed the car in maintenance mode; is it the same as the maintenance mode you can put the gen II as you see here:
    Putting your Toyota Prius into maintenance mode – getting the engine to stay running
    1. Turn the vehicle to accessory mode, Ready-off. ...
    2. Depress the accelerator two times fully.
    3. Put the vehicle in neutral.
    4. Depress the accelerator two times fully.
    5. Put the vehicle back into park.
    6. Depress the accelerator two times fully.
  4. Raul Tejeda
    Temecula
    Also, where can get a cheap copy of techstream fir Windows 10?
    Thanks again!
    R
  5. Mendel Leisk
    41,407
    Hopefully clarifies.
    SFO likes this.
  6. Raul Tejeda
    Temecula
    Please disregard; found them on Amazon at a reasonable price.
    Thanks anyway!
    R
  7. Raul Tejeda
    Temecula
    Hi Mendel,
    I figured it out; yes, it's different mode altogether. Did my breaks last Friday, following the original poster's instructions and it was a success!
    Thank you! anyway and many Thanks! to zak.kapoor for posting this great write-up.
    R
    rogerdpack, Maze62 and Mendel Leisk like this.
  8. talonts
    talonts VFAQman
    468
    76
    Techstream doesn’t require an old version of Windows, nor 32-bit. It USED to, but there are instructions out there for installing on 64-bit systems. I combined the instructions from several people into one doc that makes it a bit easier, and only have it on 64-bit machines. Windows 7 for now, but I can upgrade one to 10 to make sure it still works if someone wants verification.
    I could post my instructions, but they also include some files, from what I can remember, so I’ll need to check, it’s been a while since my last install.
    I’m not sure what you’re talking about with that last bit about “some remote person”...
    SFO and Mendel Leisk like this.
  9. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    It's the driver for the VCI or cable, not techstream that is the issue. With the correct driver it works 32 bit or 64 bit. You can also make some registry changes and make the 32 bit driver function on 64bit windows.
  10. Prius_owner
    Prius_owner New Member
    Asheville
    Hey Prius community!!!
    I just bleed my brakes on my Prius using the methods explained. Everything was going great. When I went to go start the car all the lights were flickering. The 12v battery had died. After changing it the flickering went away. Everything looked good but it wouldn’t start. It cranks but wouldn’t start and throws a don’t start code. Any ideas? I checked all the fuses using a multimeter.
    P0A0F and p3190 codes were pulled.
    thanks
  11. Mendel Leisk
    41,407
    Did you do the brake bleed with the car "ON", using some manner of invalid mode. Probably ran the battery down. It's good to have a charger hooked up while doing that that.
    I would check the voltage with a multimeter, try a smart charger session.
  12. ChapmanF
    18,149
    Didn't catch this at the time, but better late than never: accessory mode is one press, foot off brake. Two presses, foot off brake, is ON mode.
    Two pushes was probably right, because I think the procedure requires ON mode (not ACCessory, and not READY).
    Maze62 likes this.
  13. Mendel Leisk
    41,407
    I haven't seen 2nd gen brake bleed procedure without Techstream. 3rd gen yes, and it requires "invalid" mode. @Prius_owner were you following 3rd gen procedure, as far putting it in "invalid" mode? Or?
    FWIW, if I had a 2nd gen, with the absence of clear (non-Techstream) procedure, think I'd just let a dealership do it. A fair price would be around $100
  14. Prius_owner
    Asheville
    I had the car in the second position. 2 button presses without pushing the brake. I used the method explained by shorting the ports in the OBD2 port
  15. Mendel Leisk
    41,407
    Good to have a smart charger hooked up for the duration of the bleed; cheap insurance.
  16. oldshadetrEE
    oldshadetrEE Junior Member
    North East Texas
    Three Touring
    I bought a cable with Techstream but have been unable to get it to "connect" to the car. There are almost zero instructions with what I purchased for troubleshooting. Any recommendations on where to get something with a reasonable (doesn't have to be a novice-level) set of documentation?
  17. Mendel Leisk
    41,407
    I've no TS experience but lots here do.
  18. dolj
    dolj Senior Member
    8,440
    4,288
    Wellington, New Zealand
    When you plug the USB end of the cable into your computer, does it make the "New USB device detected" sound?
    In Techstream, did you check that your device is selected in the VIM selection menu? If you have MVCI, you should see two options the second showing X-Horse in the name. Make sure that one is selected.
    If it is not either of these, then we'll need far more detailed info to be of further help.
    If your Techstream came on a CD, make sure you scan it looking carefully at all the files that might have helpful setup info.
    #38 dolj, May 5, 2020
    SFO likes this.
  19. donzoh1
    donzoh1 Active Member
    448
    153
    Lenexa, KS
    So you're able to get a whole gallon of brake fluid in? Do you have the original reservoir?
  20. Mendel Leisk
    41,407
    I've done a quart, every time I "change" it. Very hard to find the spec'd qty.
