Replacing brake pad
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by hc167, Jan 7, 2009.
  1. hc167
    hc167 Member
    132
    US
    I see what you mean now. So assuming that the dealer did not change the pads for me when I bought the car. I should have a lot of miles for the pads unless the previous owner always excess of regenerative limits.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
  3. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Having just recently changed my front discs and pads on my Prius Taxi at 200,000klm,the disc part number matched that of the N/A model but the pads part number did not,if anyone has it please post it...please!!
  4. SageBrush
    11,627
    2,533
    Southwest Colorado
    I'm not of any help to you Halpos4, but I am curious why you had to replace the front discs.
  5. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    The Discs had reached their minimum thickness, although the pads were changed at 164,000klm they still had plenty of meat left on them and i would have got a few more klm out of the discs but the fact that it's a Taxi and my livelihood i'd rather not take any chances.
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    Thanks halpos4. I'm just flaunting my ignorance, but I don't understand why the disc would wear faster than the pad.
  7. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    No,i think you're asking a reasonable question,the discs lasted 200,000klm,and the majority of that mileage would have been with a full car[passengers]and probably a little heavier braking,i'm not lead footed,accellerating or braking and i tend to use "B" mode aswell,maybe some of the other Taxi/ Cabbies could let us know what kind of mileage they're getting from their pads/discs.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    The rotors on most Prius suffer more than the pads. This is because the rotors rust just while sitting there, especially in areas that salt the roads in the winter.
    Many of us find that we need to clean our rotors from time to time. The easiest way to do this is find a stretch of empty road, get up to 40 or so mph, shift into N, and brake. Slow down to 10 or 20, shift back into D and get back up to speed. Shift back into N and repeat. Do this three or four times until the rotors stop making a scraping noise.
    Tom
  9. richard schumacher
    7,666
    1,047
    United States
    Brake pads contain a piece of material which squeals when the pad has worn down. If your brakes squeal under 7 MPH that indicates that at least one of the pads needs replacing (normally one would replace both of them).
  10. hc167
    hc167 Member
    132
    US
    Base on what you said, since I am living on a hill, I can just let my car go downhill for 1 mile while it is in "N" and then fully use my brake to clean up the dust.
  11. qbee42
    18,058
    3,079
    Northern Michigan
    Yes, that should do it.
    Tom
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    Why use neutral ? Oh, to disengage regen I presume ?
    OP, beware neutral above 42 mph. One (?) of the electric motors will spin higher than spec, leading to overheating
  13. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Just an informational item re cost:
    I see in the latest service promotional mailer I get from my Toyota dealer, that they're having a coupon sale ending 1/31/09 where they'll replace the front pads with OEM pads for $79 USD.
    Don't know how much they normally charge. I'm guessing around $120 USD.
  14. qbee42
    18,058
    3,079
    Northern Michigan
    This is not quite correct. If you switch to N above that speed, the ICE will be spinning and continue to spin, so over-speed of MG1 is not an issue. If you switch to N below the cutoff speed while the ICE is not running, it is possible to over-speed MG1, but the limiting speed is closer to 60 mph. You can do it if you work at it and have a really big hill to coast down, but it is hard to coast that fast.
    Tom
  15. SageBrush
    11,627
    2,533
    Southwest Colorado
    Thanks for the correction.
  16. qbee42
    18,058
    3,079
    Northern Michigan
    You are welcome. It wasn't so much a correction as an expansion. The Prius has a lot of subtle little little quirks and special cases. I know a few. Other posters here know more. Collectively we do pretty well.
    Tom
  17. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Wouldn't you be just as well off to safely find an unused road and perform a semi-panic stop rather than using neutral? Would get the "job" done much more quickly.
    I find that simply not blowing a yellow but using semi-aggressive braking at the light is enough to keep mine clean from time to time. I always check the rear-view first of course to make sure I'm not going to be "helped" through the light via rear-end collision though.
    At 108,000 miles, my original pads aren't showing any signs of needing replacement.
  18. Patrick Wong
    18,210
    6,513
    "semi-panic" is a qualitative concept, and depending upon how hard you brake, a portion of the braking will be done via regen vs. friction.
    If you shift to N, then it is guaranteed that 100% of the braking will be performed by the friction brakes.
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    Once a week I go down a hill that is too much for my HV battery capacity. I have been switching into B mode, but I suppose it makes sense to use the friction brakes then to clean the rotors.
    More than anything, if I must be honest, the B mode use was a sop to my ego of not having my brake lights activate. :eek:
