Replacing cells in my battery
Discussion in 'Gen 2 Prius Technical Discussion' started by Gavriel Holler, Feb 22, 2021.
  1. Gavriel Holler
    Gavriel Holler New Member
    Knoxville TN
    So my check engine light, brake light, and the big red triangle with an exclamation mark light came on the other day. so I had my car read, and it showed the 5th cell block was dying. So my mother and I tried to replace the cells, put the battery back in and started the car. The lights are still on, as well as the ABS light now, and we have to unplug the orange plug on the big battery in order to turn the car off, because it would just stay on and make clicking sounds. Is there possibly something we did wrong or missed, does anyone know why this is happening? I also scanned it and these codes came up: C1259, C1310
    #1 Gavriel Holler, Feb 22, 2021
  2. dolj
    dolj Senior Member
    7,841
    3,959
    Wellington, New Zealand
    Very possible. Do you have a photo of the battery wiring? If not, can you get one?
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,061
    Columbia, SC
    Take a few good photos of the electronics section of the battery and post them. If there's something wired incorrectly, we should be able to see it.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Did you disconnect the 12v ? I just did SWMBO's Gen 2 and disconnecting the 12v cleared the lights.
    Another thing is, did you check each cell voltage ?
    Torque app only showed one low cell (pair) on ours but when I left it stood for a week, disconnected from the car and with the bus bars off, I found two individual cells were lower than the rest by almost 2 volts, so I replaced the two.
    I don't know if you know but the cells are counted from the end opposite the ECU.
