Replacing engine water pump 2013 v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Sacko107, Mar 16, 2019.
  1. Sacko107
    Sacko107 Junior Member
    Ct
    2013 Prius v wagon
    I couldn’t do a search so I apologize if there is already a thread on my problem.
    I have a 2013 Prius V with a check engine light. Took it to the mechanic read the codes has no electric feedback from the water pump. I’m getting heat after the car has run for a little bit. They’re quoting me $1100 to replace it. Is this a DIY job? And what recommendations can you make for which water pump to buy?
  2. hchu1
    hchu1 Active Member
    316
    128
    Houston, Tx.
    2014 Prius v wagon
    Here is a video:
    Check Rockauto for the pump get the Aisin, they manufacture for Toyota, $250. Also, get the rubber gasket don't reuse the old one.
    If you don't diy, find a independent who will charge labor only and you supply the part. Your drive out price should be way less than dealership shop.
  3. mikefocke
    4,083
    1,864
    Sanford, NC
    Smart mechanics don't do installs of parts people just bring in lest there be a defective or missing part and then the shop and the connected tools (lift, for example) would be tied up while the car owner deals with getting a new part. The shop owner is entitled to some "profit" for handling the parts. So don't be too surprised if they don't want to go this.
  4. Sacko107
    Ct
    2013 Prius v wagon
    Thank you. This is really helpful
    That makes sense. I’m in home-improvement and we typically don’t install customer supplied material, it usually causes problems because they don’t order enough and feel entitled to micromanage our crew
    #4 Sacko107, Mar 18, 2019
  5. Sacko107
    Ct
    2013 Prius v wagon
    I went to a shop that I trust. They’re very good mechanics and do all the work on my wife’s car. They typically give her very good deals because she advocates and refers a lot of customers to them. I’m just having a hard time wrapping my head around $1100 to replace this part. He initially said $1300 then corrected himself and apologized
  6. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I’ve done the job and not sure where that price comes from;).
    The pump is the most expensive part and the only other thing you need (short of coolant) is the form-a-gasket. But I guess if you go to toyota for te pump the price is 2x what the rock auto price is for the exact same pump:cool:.
    Good luck and keep us posted (y).
  7. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Unless the shop really knows the customer, and knows the customer knows all of what the job requires, and doesn't have the facilities to DIY.
    I am lucky to have such a shop. Especially for the ancient sports car.
    #7 Air_Boss, Mar 18, 2019
    Raytheeagle likes this.
  8. ivfx
    ivfx Junior Member
    36
    Dhaka Bangladesh
    My 2010 had its water pump replaced by my dealer at a Toyota dealership before I bought the car. It was still under warranty from Toyota when I bought it. While I can’t say much it cost him, I am assuming somewhere around $500.
  9. Sacko107
    Ct
    2013 Prius v wagon
    Again thank you. I’ll let you know how it goes!
  10. Sacko107
    Ct
    2013 Prius v wagon
    So my son came over before I got back from work. He replaced it in about 2-1/2 hrs start to finish.
    I’ve been trying to run in maintenance mode and circulate air out but can’t find instructions. I followed the instructions on YouTube but it does not end up showing maintenance mode on the dash like it does in the videos
    If I’ve set the car in maintenance mode will the hybrid warning system trigger?
    Any instructions on setting in the maintenance mode?
  11. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Key on, engine off...
    Immediately perform the following:
    Press accelerator twice while in park
    Shift to neutral, press accelerator twice.
    Shift back to Park, press accelerator twice
    At this point you should see “maintenance mode” appear.
  12. Sacko107
    Ct
    2013 Prius v wagon
    That’s the procedure I followed. I did it several times and “maintenance mode” never came on the screen. The hybrid warning (yellow car with ! through the middle) started flashing and gas engine ran continuously. I was nervous with that flashing so I only let it run for a few minutes.
    Thank you for the feedback everyone.
    Regarding the water pump.. my son came to the house after work. I was late getting back. He had the car apart by the time I got there. New pump was in and finished in less than an hour. It took longer to put the bottom guard back on and bleed the system! Just drove a couple hours and all seems good.
    Thanks again for the advice guys.
  13. The Critic
    3,193
    2,333
    CA
    Each step must be performed within 5 secs. Could that be why?
  14. Sacko107
    Ct
    2013 Prius v wagon
    That’s what I originally thought and that’s why I repeated it so many times
