Replacing Gen 2 Key and Key ECU
Discussion in 'Gen 2 Prius Technical Discussion' started by Tom in Maine, Nov 8, 2017.
  1. Tom in Maine
    Tom in Maine Junior Member
    23
    Searsport, Maine
    Am buying a 2008 with no key. Dealer said they cannot program a new key, since they believe it needs a new ECU. Of course, their cost is ridiculous.
    I have salvage cars I can pull keys and the ecu from. Just am a bit confused as to which ECU(s) I need to swap.
    Might go and try to do the swap rather than tow the car, if it is not too hard to do on site.
    I appreciate any guidance.
    Thanks,
    Tom
  2. JC91006
    16,923
    8,634
    Ask the dealer to do a reseed of the keys. Labor and key should be around $300
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Or find an automotive locksmith. Generally cheaper than the dealer.
  4. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    If you don’t want to get control units reprogrammed you need to replace 3 or 4 control units. All of those control units are programmed to each other. So you need to take those units and the keys from the same car. Units are: Immobilizer ECU, Smartkey ECU (if your Prius has keyless entry and start), Engine ECU, and HV ECU.
    SFO likes this.
  5. Prodigyplace
    12,708
    11,847
    Central Virginia
    That is all the major ECUs isn't it?
  6. Tom in Maine
    23
    Searsport, Maine
    That is what I need to know.
    Will update once I have the car. The dealer could not program a new key, they said it needs a new ECU and then it would work.
    Have Techstream but not sure how far I will get without being able to start the car. Suspect not very far.
    This is why I keep scrap cars. LOL
    Thanks,
    Tom
    Prodigyplace likes this.
  7. Tom in Maine
    23
    Searsport, Maine
    Got it all converted over. Key works. Gas motor does not start. It is seized!
    It was a repo. I can see why it was let go.
    We will transplant a new motor in.
    Had to change all four ECUs but at least I have this one under my belt.
    FYI for those of you who might endeavor this. It is MHO that the Prius dashboard is pretty decent to work on.
